What would be the best material to use to wrap my deck posts? The posts are 6x6x10’s and will see a lot of weather. I plan to box them out and add crown and cove moldings. The deck rails and floor are trek. I live in North Georgia. Thanks in advanced!
Luke
azec or similar.
You can get it in board sizes or full sheets. You can mill out profiles and some yards stock trim moldings made from it too.
Thank You. What would you seal the joints with?
Luke
Azek glue, Bond-n-fill, or plumber's cement.
Azec glue or Bond'n'fill
Have you tried plumber's PVC cement? It stinks and sets up really fast, but seems to have held up on a few joints where I ran out of Azek glue.
Yes on samples.Azec actually has a latex glue and a PVC cement - or used to. I don't think the PVC cement is much diff from a plumbers PVC glue. Maybe only a different label.
I didn't know about Azek's latex glue. I've used gallons of their pvc cement though.. It doesn't stink, unlike plumber's pvc cement, and it sets up much slower. Seems like someone mentioned why it's not as good as Azek's slower setting stuff though.
I believe the difference is the Azek glue is water clean-up. Therefore if one is NOT going to paint their Azek (that's me) the surface is not
stained.
That is the Latex glue.
This is the stuff I've used:
It's water-cleanup pvc cement--is this what you're describing as latex glue?
Mine isn't labeled "Main Image";)It is white and milky as I recall.Used to have some that melt-welded the pvc like plumbers stuff does. Not sure that they still make that, but last time I ordered the guy asked which I wanted. Since that was an interior application, I got the latex
OK - stranfgely enough - that image did not show up until I posted the reply. Looks like same I used as a latex water washable
Hmm. IIRC, what I've used is yellow. It's been a while though.
I've used Master Mechanic pvc cement, don't. The stuff with some green on the label, that plumbers usually use, has always done the job.http://www.tvwsolar.com
We'll have a kid
Or maybe we'll rent one
He's got to be straight
We don't want a bent one
He'll drink his baby brew
From a big brass cup
Someday he may be president
If things loosen up
we use the Azek glue... a little yellowish.... very thick..... not a lot of working time... but pretty good water clean up
i think i prefer it to pvc plumbers glue
we pay about $20 for the big can, $14 for the small can... i drive my guys crazy bitchin about the caps not screwed on between uses
Edited 7/11/2009 10:23 pm ET by MikeSmith
Do you know about http://www.garymkatz.com/
He has articles with lots of pictures on doing just what you want to do.
Cant remember if he talks about material though, more so on how to wrap the posts correctly.
I take it you have already done the railings? If not, I was going to suggest the composite post skins that slip over the posts. Otherwise, AZEK or similar would be fine. I did some using 1x6 stock, then filled the corner edges with 1/2" quarter round. No glue necessary.
