Deck prices
fartherhome | Posted in General Discussion on June 6, 2013 05:20am
I know I’m gonna get yelled at here.
I only do decks occasionally and I’m coming up with numbers that look high to me.
What I’m looking for is a range in cost  using pressure treated decking and rails and including the drawing and permitting.
The first deck is about 5′ off the ground, a 12′ x 12′ square ,bolted to the house on one side, with one 3′ wide stair.
The other will use the same material, 3′ off the ground, with a 4′ wide stair. This deck will be about 150 sq’ and an odd shape to avoid an A/C unit and a basement stairwell. One side will be supported on a retaining wall if the County oks it. (will they?)
The only thing that might raise the cost beyond the norm is that the rails will die into capped posts. I hate those mitered corners.
Thanks,
Mike
  1. junkhound | Jun 06, 2013 08:30pm | #1
    Doing 2 decks this year.
    One 10 ft by 6 ft so samller thqn  your examples, but with railing only on one side as 1 side against he building, one side 6 ft wide stairs, and 4th side <30" high.
    About 1-1/2 day labor, the 1/2 day doing layout and pouring 4 cu ft each concrete piers.
    Total cost about  $60 PT lumber (I take the culls at the big box at 75% off, 95 out of 100 can be aniled flat), otherwise PT lumber about $240.
    - $20 hardware (sesmic anchors required here)
    -  galv nails about $15 worth
    -$10 concrete (80# broken bags are only $1 ea at big box), otherwise, $40)
    So, say labor plus $105 if you stockpile materials when they are available, otherwise $300+railings.
    I used salvaged 'free' welded iron railings (often seen on CL), weld 2 ea overlapping 5" spacing rails discarded for <4" spacing to meet current code
    So, at $50/hr, $600 plus $300, plus railing plus profit is over one grand or about $15 to $20 sq ft.
    Add another $200 for permit/fees if ya cannot get by without one, +$100 sales tax here.
    1. fartherhome | Jun 09, 2013 11:03am | #2
      Deck prices
      Thanks,
      But I can't make any money at that square foot price. I'm not culling, not reusing, and i will have to spend more than a day each estimating, drawing and permitting these decks.
      Do you have any idea of an average range?
      Mike
      1. junkhound | Jun 10, 2013 10:26am | #3
        you may find some pricing data in the archives,
        Bob S. (ProDek) was the decking guru in the old days, but he did high end stuff, likely around $40 sq ft 5 years ago.
Picture-Perfect Pergola
