Deck rails into concrete hidden system
cleanwater | Posted in Construction Techniques on April 24, 2005 04:33am
I have a concrete patio job upcoming and would like some feedback.  Patio is planned to have a stone veneer in mortar next summer therefor rails go on first.  No biggie I can set them high and trim post next summer.  H.O. wants to use composite (prob. trex) material for the rail system.  I usually work with wood i.e. cedar/pt. I don’t do much interface with concrete and I have some concerns.  I have never used composite for stuctrual (I dont want to use it at all ).  H.O. found Trex website with 4×4 posts and wants me to use them.  Trex says alot of stuff but what do you all think about the 4×4’s.
I am considering- setting allthread into the concrete and predrill (how deep? 2/3?) posts epoxy, and insert.   and or angled brackets lagged into concrete and recessed into post and hidden with trimmed 1x overtop.
Do they sell a post anchor that would work with this application? Is it easily hidden?
  1. CombatRescue | Apr 24, 2005 06:33pm | #1
    The Trex I've seen is designed to slip over a 4X4 wood post.  I didn't realize they made a solid posts, but a quick look at their website confirms they do.
    I think you're best bet is to call the manufacturer to see if/how this can be done.  You don't want to risk a lawsuit for improperly installing something as important as deck railing, or void the warranty for that matter.
