Constructing a deck on a sloped roof and have cut my PT sleepers (1/4″ / foot slope). Should the cut or factory side face the deck? Will cover the deck or down side with leftover EPDM, but should I do anything additional to treat/seal/stain the cut side? Decking is 5/4 x 6 Ipe. Thanks for the input!
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
if yer using deck boards why the slope? the top is not solid.
is the roof sloped?
I'd do the sleepers to match the roof slope and the deck level, so I'd go with cut side down..remove the sleeper material to accomodate the uphill of the roof.
a T&g deck surface I'd slope cuz the water can't run through the cracks..
Most PT is not uniformly saturated -- the cut side will be relatively untreated. If the material is going to be sitting on a sometimes-wet surface, having the factory side down would put the treatment where it does the most good. However, you then have the (relatively) untreated side facing up, catching the rain, so it would probably be a good idea to at least go over the cut surface with some sort of sealer/preservative.
Roof is sloped - sleepers will account for slope to create a flat deck. Dan, thanks for the thoughts - recommendations on sealer/preservative?
Alas, there ain't no good ones, just a bunch that are so-so (and the selection varies as the pollution laws change). Definitely not Thompson's, of course.
Use the green copper napthanate preservative. Jasco Termin-8 is one brand. Wear gloves, glasses, and a respirator. Nasty stuff, but effective.
Bugle
Just a thought. If you opt to put the cut side down you may want to use an 1/8" round over on it so it dosent cut into the EPDM.
I'd add a second strip of EPDM (?)under each sleeper with a self sealing membrane.
My life is my passion!
Good suggestions all round. I cut strips of extra EDPM an inch or two wider than the tapered 2x sleepers and spot torched them onto the existing roof membrane. Granulated side up so it doesn't act like sandpaper on the membrane. Placing the slepper cut side down produced an even surface for the decking. I will seal the exposed cut with JASCO most likely. Interesting that the new PT wood seems to have inconsistent preservative penetration.
may be a dumb question, but what does EPDM stand for?
Ethylene-propylene-diene monomer
edit for spell check with google
Edited 5/24/2004 4:24 pm ET by SPHERE
Its a roof membrane utilized on "flat roofs" that is torched down. Many insurance carriers are not excited by roofing subcontractors utilizing the material because of the fire risk. Great stuff with a granulated textured surface.
