Deck stains
konopam | Posted in General Discussion on June 5, 2007 04:37am
I am in the process of reviving a deck that has not been stained for over 4 years or more. It appears that some of the deck was built with cedar and some of it was built using green treated.  My question to all is after cleaning the deck with a solution and power washing it, what deck stain product would you recommend?  Will there be any problems using the same stain to make the deck match since some is green treated and the other parts are cedar?  Thanks for your help and answers
  1. rez | Jun 08, 2007 07:55pm | #1
    Greetings k,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Under the most splendid house in the city is still to be found the cellar where they store their roots as of old, and long after the superstructure has disappeared posterity remark its dent in the earth. The house is still but a sort of porch at the entrance of a burrow.     -Thoreau's Walden
    Dinosaur | Jun 08, 2007 10:54pm | #2
    There is no transparent penetrating wood stain I know of which will give you an even colour across two dissimilar woods. You will need to use a solid stain, which is very much like paint but penetrates more. It is a common product to use on decks, however it does wear off and will need to be re-applied periodically.
    Some products to not adhere well to PT wood. Check with the manufacturer of the one you would like to apply before purchasing it. He may recommend a primer or recommend a different product altogether.
    Dinosaur
    foolish men call Justice....
  3. silver | Jun 11, 2007 05:56am | #3
    I recently added some new cedar stairs to an old PT deck. Then we stained it all with Superdeck-redwood stain. The cedar was a different
    color but the owner loved it...
    I would try some on a sample ...it makes pressure treated wood beautiful
    and wears well.
    silver
    1. konopam | Jun 11, 2007 03:22pm | #4
      Thanks all for responding, you hate to try this on site if you know what I mean
