decorative column
dt20204 | Posted in General Discussion on February 12, 2012 10:31am
I have a load bearing wall (~18′) that I plan to remove and replace with a beam to open things up a bit.  Considering height issues, the load that this beam is carring etc, I have determined that I need to cut the span down.  The plan is to add two columns ~3′ in from each end.  Then I would like to dress up the two 3′ areas with a half wall and decorative column like the attached photo.  Anyone have a source of split decorative columns ~4′ in length.  I prefer wood, the end finish will be paint and the interior of the decorative column needs to be hollow (to house the structural column).  FWIW, I am in Massachusetts…  Also, considerations for the newly created point loads are underway…
  1. calvin | Feb 13, 2012 06:29am | #1
    dt
    Have you contacted your local full service lumber yard?
  2. calvin | Feb 13, 2012 01:31pm | #2
    This is not easy......
    and I'm sure you'll have to ask around.  I assume you are stuck on the round column.
    If what I have in the shop would work, come over and make an offer.  Course I'm in Ohio.
    I am meeting with a customer that supplied me with two column wraps, but these were square.  They were sent to him to rough length, had trims included and were 4 pc, lock mitre for the corners.
    Since he procured online-maybe if he remembers where he got them I can give you that-you pursue if they have half rounds that can be joined.
    Now, if I don't lose this postit note-I'll be back.
  3. calvin | Feb 13, 2012 01:42pm | #3
    I just "Bing'd" round wood columns
    came up with this first off:    http://www.elitecrownmoldings.com/home.php?cat=5
    They will sell you structural columns-
    or
    split wood columns.
    Take a look.
  4. calvin | Feb 13, 2012 02:44pm | #4
    dt
    If you go square, you certainly could make that up yourself.
    Inset panels?  Yessir, that would look good.  Tapered a bit more work and thought, but not beyond build rather than buy.
    Work right around your support post.
  5. [email protected] | Feb 13, 2012 03:27pm | #5
    Try Osbourne Wood Products
    Osbourne Wood Products has a pretty broad selection of architectural columns.  Not exactly as you picture, but enough options to get you close.  They sell the bases and capitals seperately.
    Vandykes Restorers might also have what you need.
    If you have a Woodcraft store near by, they might have bulletin board, or be able to hook you up with someone who turns spindles. Or try posting over on the Knots forum at Fine Woodworking, there is a link at the bottom of the page.
    You could also buy "Router Magic" by Bill Hylton, he has plans for a router lathe in the book that could easily produce whatever profile you want.
