Decorative Wall Shingle Application
Scott | Posted in Construction Techniques on April 9, 2010 07:17am
See the pics.
We think that this might suit the character of our house, though in a different stain color.
How do you figure it’s done? Looks to me like a simple case of snapping two lines (at the proper reveal distance) about 3/4″ apart, then alternating shingles between the lines. Clearly, the shingles are random widths.
Thanks,
Scott.
  1. DanH | Apr 09, 2010 08:36pm | #1
    I think it's a matter of having just enough to drink, but not so much that you fall off the scaffolding.
    Or else you set a reference board for the lower shingles and then use a cut-oiff piece of shingle as a spacer to space up every other one.
    1. Scott | Apr 09, 2010 09:20pm | #2
      I like your first approach.
      1. MikeSmith | Apr 10, 2010 06:51am | #3
        those are tapered splits....
        they are  a little random in their length
        you snap a top line and lay the tips on the line instead of the butts....your line spacing remains constant
        in the pictures.... the biggest problem id the windows have no  sill...and the casing is too narrow
        1. Scott | Apr 10, 2010 11:32am | #4
          Yeah, I noticed that too... I think this house is still a "work in progress", but I don't know the owner.
          You think so? It looks like a fairly constant rhythm of about 3/4" up and down to me.
    popawheelie | Apr 11, 2010 10:03am | #5
    Good eye on that. The windows don't match the style of the house.
    popawheelie | Apr 11, 2010 10:06am | #6
    shingles
    I think you could just snap the lower line and just offset the higher one. I want to do some of this on my house.
    As long as one hight is consistant your fine. The other heights are supposed to be a little random.
    1. Scott | Apr 11, 2010 12:00pm | #7
      Hey Popa....
      I found this (see attached file). It's from here:
      http://www.cedarbureau.org/installation/wall-manual.htm
      See page 11 - Staggered Butt Coursing.
      Good luck,
      Scott.
      File format
      1. DanH | Apr 11, 2010 01:57pm | #8
        See, I knew a staggering butt had something to do with it!
        1. Scott | Apr 11, 2010 10:25pm | #12
          LOL...Oh man, the corn is gettin' pretty tall around here....
      2. MikeSmith | Apr 11, 2010 08:49pm | #9
        the reference
        link is for  rc  squared and rebutted
        the original  poster showed pictures of taper sawn splits... you can tell by looking at the butts... they are not  squared and rebutted
        taper sawn splits are not  uniform in length......even if you lay the butts all on the same line... they will have  a slight staggered appearance
        if you lay the tips  to a line.. there  will be a lot of stagger... about an inch of variance
        1. Scott | Apr 11, 2010 09:42pm | #11
          Thanks Mike.
          I'm the OP, but I also asked the question about the stagger. Thanks for the info on taper sawn. I'll have to look into that. Never heard of it until you mentioned it.
          1. MikeSmith | Apr 12, 2010 06:07am | #13
            we get all varities ...
            of shingles and shakes in rc...
            rc 18"....red label / blue label
            rc 18"  ...#1 perfections
            rc  18".....r&r (resquared & rebutted ).... that's the standard sidewall shingle
            roofing we would  usually spec a  "thick butt"
            in shakes there are "hand-splits"
            and  "taper sawn hand-splits "
        popawheelie | Apr 11, 2010 09:12pm | #10
        Thanks!
        I put the websight on my faves. I'm going to do decorative shingles on gable ends. Should be fun.
        I'm thinking the real intracate center piece will be done on the ground and applied as a unit.
A New Approach to Foundations
