Still fighting with the county, What is the proper definition of “threshold”
Listeners write in about saving frogs, attic ductwork, lime wash, and energy ratings for real estate.
It was defined a couple of months ago in:
http://webx.taunton.com/Webx?128@@.ef192ec
*O.K. let me rephrase the question. "What is the government inpector definition of threshold?"
*i "What is the government inpector definition of threshold?" Not being a smart alec here, but you'd hve to ask him what his (or the governement's) definition is.James DuHamel
*Johnnie, ask your question in a different way. What is the argument about?
*The threshold is how far you can push an inspector before he puts a stop order on your project ;-)
*The simple answer is "a raised divider between differing floor heights and/or materials" but Rein Taul has a better answer. Building codes are like the Bible, all subject to differing interpretations. You might want to try less "fighting" with the county and more "discussions" as to why an inspector wants a given element and what options they would consider if you have problems complying. the more you argue the bigger your headaches!
*My question is: Is the threshold the metal strip under the door or is it the landing platform elevation in the doorway area. CABO/ANSI A117.1 claims for a handicapp entrance to 1/2 inch maximum with a cahnge in level: 1/4 inch high maximum vertical change. As far as discussion with county, I have not said two words to him, Every time I get inspected I make sure no body on site so he can take his time look around, I leave a set of blueprints on site for him. Last time he paged me and when I called back minute later he torn me a new as*#$%e on the phone. ( I kept quiet) upon arrival at site later I had a rejection ticket due to porch elevation. I was pouring slab not porch. My house is designed to a strict SBC/ANSI spec. But county does not care.
*Why you avoiding him?Communication works to prevent problems like tooth brushing heads off cavities.Be there with coffee and cookies and a smile for him.I know some are real a$^^$&^%s but most are just guys with a job to do.
*Piffin has the right of it, at least as far as coffee and a smile, not sure about the cookies. Dealing with any inspector (home building or manufacturing, etc.) is always best done face to face. Sure, I've had my share of arguments, dealt with inspectors having a bad day (month). I find it's still easier face to face than later, on the phone. As for "thresholds at doorways" ANSI A117, section 4.13.8 reads: thresholds at doorways shall not exceed 3/4" in height for exterior sliding doors OR 1/2" in height for other types of doors". It goes on to say "raised thresholds and FLOOR LEVEL CHANGES at accessible doorways shall be beveled with a slope no greater than 1:2". Furthermore, changes in level up to 1/4" may be vertical and without edge treatment. Changes in level between 1/4" and 1/2" shall be beveled with a slope no greater than 1:2. If the change is greater than 1/2" a "ramp" might be required and a whole new set of reg's apply. Hope this helps.
*I really wasn't advoiding him on purpose. I just work a 40 at my regular job and then at the house after 3pm and weekends, Usually inspection are schedule at their conviental.
Still fighting with the county, What is the proper definition of "threshold"
