Dehumidifier??
Adele | Posted in Energy, Heating & Insulation on July 21, 2003 04:11am
In the never ending quest to lower my electric bill, I have been thinking of buying a dehumidifier, with the thought that with low humidity in the place, the A/C won’t have to work as hard.
1 bdrm, no clue as to the s/f, but it’s small, it’s one half of a duplex, concrete, windows only 4 yrs old & close tight. No vent in bathroom but I do put the fan in the doorway aiming to the open window when I use the shower. Ummmm, one wall unit A/C. Windows kept closed all day, blinds closed too. Only run the A/C when at home- morning & after work- goes off at bedtime. What else? Oh yeah, I’m in a slightly humid place- Orlando. LOL
TIA
But, but, its SUPPOSED to taste like that!
  1. ahneedhelp | Jul 21, 2003 04:41am | #1
    A typical dehumidifier will generate heat as it works.
    In addition to having to spend money to buy one, it will add insult to injury by heating up the place as it dehumidifies.
    Window A/C units these days are more efficient with better controls. Some of them even come with, thermostat, timer and remote control. You may want to shop around and see what's available. There are also floor standing units that has vent tubes that channel the hot air outside.
    Are your concrete walls (or whatever it is) sealed with some sort of barrier paint or coating ?
    Is your unit below grade ?
    rjw | Jul 21, 2003 05:20am | #2
    A dehumidifier is essentially a refrigerator without a box to stick the milk in.  I believe they are generally expensive to run, as most refrigerators are.
    I don't know if there is a net gain of heat from them, but I strongly suspect that, as already noted, you're better off using you A/C to dehumidify - getting dual use from the same refrigeration cycle (dual since the A/C moves heat from insdie to outside while it also dehumidfies - and A/C unit is also a frig without a  place for the milk).
    _______________________
    10 .... I have laid the foundation like an expert builder. Now others are building on it. But whoever is building on this foundation must be very careful.
    11 For no one can lay any other foundation than the one we already have--Jesus Christ.
    1 Corinthians 3:10-11
    BillHartmann | Jul 21, 2003 06:01am | #3
    In general a lot more of the energy is used to remove the humidity then to cool the air.
    What you need to do is to get a humidity meter for inside the house and also learn to read the electrical meter.
    It is probably cost you MORE to shut the air off during the day.
    Specially if you are open the windows.
    You are probably much better of getting an electronic setback thermostat and running the AC at maybe 80 during the day.
      rjw | Jul 21, 2003 06:35am | #4
      Bill, as a side note, does that mean that I will get a lower A/C temperature delta on when the humidity is higher?
        BillHartmann | Jul 21, 2003 07:34pm | #5
        Bob
        "Bill, as a side note, does that mean that I will get a lower A/C temperature delta on when the humidity is higher?"
        I *think* so.
        It has been almost 40 years since I had thermodynamics and that was based on gernic systems and not real world design. I am not sure what affect the temperature controlled expansion valves have.
        The extra work required to condense the mositure has to be reflected in either less cooling of the air or reflected back as an increased load on the motor and thus higher power consumption.
        This summer I had to get the AC serviced and did not run it until it was done and that was the after it had gotten hot and humid.
        The guy has it almost filled when he ran out of freon. So it ran for about 45 minutes while it got some more.
        In that time the humidity level dropped about 5 points, but the room temp did not budge.
          Adele | Jul 22, 2003 04:23am | #6
          Appreciate all the info. Thanks for saving me the $ on the dehumidifier!
      2. TLRice | Jul 23, 2003 04:07pm | #7
        Bob,
        What he is kinda refering to is the fact that the average air conditioner evaporator coil is only 2 or 3 rows deep and can only remove so much energy at a time. The energy absorbed by the refrigerant as water condenses on the coil, is energy that will not be removed from the air. Typically, at a given flow rate and face velocity, an evaporator coil will have a fixed capacity raitio of the latent (i.e. dehumidification) capacity to total capacity.  So in a word, yes, this means that at higher humidity the temperature drop across the coil will be less, all other things being equal.
        Tim
          rjw | Jul 24, 2003 02:48am | #8
          Tim, thanks_______________________
        2. DaveRicheson | Jul 24, 2003 04:40pm | #9
          Where have you been? Thought you were MIA.
          Welcome back.
          Dave
          1. TLRice | Jul 30, 2003 04:37pm | #10
            Dave,
            I am MIA and thanks for noticing. Just don't have the time anymore.
            Tim
Picture-Perfect Pergola
