Anyone use the new Delta #36-412 miter saw?
What are your thoughts/experiences?
Thanks!!
“Objects in mirror appear closer than they are.”
Klakamp Construction, Findlay, Ohio
Thanks!!
With the right approach, you can restore old hardware—whether through soaking, scrubbing, or polishing—giving it a fresh look while preserving its original charm.
I traded up from the single bevel and like it a whole lot the only thing is my crown clamp doesn't work on it. I have mine mounted on a delta stand which works well also.
ANDYSZ2
I MAY DISAGREE WITH WHAT YOUR SAYING BUT I WILL DEFEND TO THE DEATH YOUR RIGHT TO SAY IT.
Thanks, Andy.
Is your Delta stand the side kick stand? How well does the saw fit on it?
Bryan"Objects in mirror appear closer than they are."
My mistake I have the dewalt saw not the delta.I have the delta stand and like it a lot my saw did not mount up exactly so i couldn't use the fence that came with it but still is a nice setup.
My concern was whether or not the Delta #36-412 would fit on the stand. I have a message to the Delta Corp. to see if it is compatible or not.
Anyone else using the new Delta #36-412 miter saw?"Objects in mirror appear closer than they are."
I have that saw on that stand... It didn't fit exactly the way I wanted it to, but I love both the stand and the saw, so I made it work. The thing I don't like is I can't put the saw at the 60* mark to store or transport it. The saw keeps hitting the wheels. But all in all, I like the setup.
Delta Corp said that the 12" dual bevel saw would fit on the universal miter saw stand."Objects in mirror appear closer than they are."
