Delta 12-Inch Variable Speed Wood Lathe & Duplicator
I just put up for sale on eBay a Delta 12-Inch Variable Speed Wood Lathe & Duplicator (for local pickup in Katonah NY).
We used it for three projects a couple of years ago and since we now sub out all of our stair part production it’s been sitting around gathering rust since them.
Still it’s a great tool. Relatively easy to set up, has good smooth variable speed control, and its easy to find parts such as chucks and other accessories for it. If you are just getting started and want a lathe that you will be able to use until you become really serious about turning, this is a great choice too.
The Delta 46-408 Wood Turning Duplicator features an aluminum bed and carriage. Creates matched spindles and is designed for use on Delta 14″ and 16″ wood lathes (models 46-745, 46-746, & 46-715) and most other 12″-16″ units with cast or channel bedways36″ max duplicating length, 6″ max duplicating diameter, 3″ max duplicating depth. Max diameter of original spindle – 5″. 1/4″ max depth of cut per pass (1/8″ recommended).
Included are accompanying tool wrenches and an 8 p.c. Great Lakes Lathe Chisel Set
If you have any questions feel free to contact me via email or by my business phone number at 914-301-5838
