Delta Multichoice R22000 – trying to determine stringer width
pulper_11 | Posted in General Discussion on March 31, 2021 10:52am
I’m trying to figure out the stringer width for the install of my r22000.
the manual indicates the distance from the stringer to the finished wall needs to be 2 9/16″ +/- 1/4″.
my walls are 2×6. therefore that’s 5.5 inches deep.
i’m using 1/2″ kerdi board.
the ceramic tile going on top of the kerdi board is 9mm thick (0.3543″).
i don’t know how to account for the amount of thinset between the kerdi and the tile. without thinset, i end up with a stringer width of 3.79″. That’s:
5.5″ + 0.5″ + 0.35″ – 2.5625″.
Two questions:
1. how much should i account for with thinset (using all-set).
2. do you think i’ve missed anything in my calculations?
thanks!!
  1. catmandeux | Mar 31, 2021 01:25pm | #1
    Thin set should be between 3/32" and 3/16" thick when the tile is set in.
    I would use 1/8" if the tiles are small and smooth. If using larger and rougher tiles, use 3/16.
    When setting the stringer, measure from the finished wall side of the stud.
    Total finish wall thickness will be ~1". Set the stringer 1-9/16 back from front of stud.
  • Townhouse Transformation
  • Mortar for Old Masonry
  • Grout-Free Shower Panels
