Delta Sawbuck Frame & Trim Saw: What Is the Size of the Arbor Wrench?
I need to change the blade on a Delta Sawbuck Frame & Trim Saw. The nut in front fits a 5/8 socket. But can’t find the size for arbor wrench that goes behind the saw blade. The instruction manual didn’t say anything.
It’s a cool looking beast.
thinking maybe a parts diagram might help(?)
good luck
https://www.mikestools.com/Delta-Sawbuck-Frame-Trim-Saw-Parts-Lists_2292.aspx
If the parts diagram doesn't have the info you could call Delta and speak to a product specialist.
Should be able to slide a caliper in there to gauge the nut.
Just to have a closure, the right part is: Delta Wood Lathe 1-1/4" Wrench part number 422-25-101-0001 sub for 434-08-101-0002
