Demo of reinforced concrete porch floor
Emmazdad | Posted in General Discussion on August 21, 2008 02:13am
Hello folks.  I have a 21’X12′ reinforced concrete porch floor that needs to go before it decides to do it by itself.  I’ve read lots of old posts about breaking up concrete but can’t find any that address how steel reinforcement affects the job.  This slab is over a block garage that is also in bad shape, so this floor spans an area somewhat smaller than the above dimensions.  Some exposed rusty rods and grid showing below where the concrete has started to crumble.  Does the steel mean this demo is strictly for the pros?
Thanks!
John in Pittsburgh
    fengelman | Aug 21, 2008 07:57pm | #1
    no, but the fact that it's a roof, and therefore so many feet up in the air, says that discression might be the better part of valor
    seems to me someone posted a link to something similar, once upon a time, where things went to hell in a handbasket really quickly
    I wish I didn't know now, what I didn't know then
    Sphere | Aug 21, 2008 08:29pm | #2
    Hire a track-hoe and dump truck. Sounds like the whole shebang has to go. They can do it, you're better off watching.
    Edited 8/21/2008 1:30 pm ET by Sphere
    Dinosaur | Aug 21, 2008 09:03pm | #3
    Pro-only, I'd say. The slab could possibly be cut away and dropped working from a scaffold, but the whole thing is dangerous. It will likely fall on an angle once the first two sides are cut, and when the rest is dropped it could blow out the block wall real easy.
    You're most likely gonna lose that garage in the process no matter what you try.
    Dinosaur
    foolish men call Justice....
  4. DaveRicheson | Aug 21, 2008 10:27pm | #4
    If the "potch floor" is tied to a foundation wall of a house, it could be more dangerous than has been mentioned thus far. Dropping that puupy wrong could blow out or pull out the foundation wall or cause some serious structural damage to it.
    In the past we would cut and jack hammer out a strip of the floor next to the foundation wall to expose as much of the reinforcing steel as possable. All of the connecting steel would be cut away by torch or saws-all, and only then would we start to demo the remainder of the slab with a trackhoe and hole ram.
    1. Emmazdad | Aug 22, 2008 04:21pm | #5
      OK, well I'd say that's a big ol' don't-do-it.  I'm really grateful for the answers.  Breaktime is filled with stories of projects that didn't turn out to be so easy after all, but the potential for disaster with my porch slab is now crystal clear.  Many thanks.
      John in Pittsburgh
