Demolishing a thickset mortar bed
maxspektro | Posted in General Discussion on February 25, 2009 01:09am
I’m doing a bathroom remodel, which means removing the old (ugly) 4 in. sq. ceramic tile from the walls and then demolishing the underlying thickset mortar bed. It’s circa 1950 when they made things to last. The mortar is attached to a metal lath which is placed over 3/8″ thick gypsum board (the kind with the holes in it); both lath and board are nailed to the studs. After removing the tiles, I’m wailing on the mortar bed with a 5 lb hammer to crack the mortar then chiseling it off until I get down to the lath, which I can pry off. Great exercise but not much fun. Does anyone have a better idea?
Thanks,
Max
    IMERC | Feb 25, 2009 01:18am | #1
    Bosch SDS plus RHD and a flooring chisel...
    now get back to work...
    http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=11255VSR
    http://www.boschtools.com/Products/Accessories/Pages/BoschAccessoryDetail.aspx?pid=301
    WOW!!! What a Ride!
    1. maxspektro | Feb 25, 2009 01:48am | #2
      Thanks, sounds like just the ticket -- Bosch makes good stuff. I assume that a relatively wide chisel like the 1.5" HS1427 would be what I want. Would you attack the mortar bed straight on (perpendicular to the wall), or attempt to "shave" it off in a more vertical fashion?
        IMERC | Feb 25, 2009 02:46am | #5
        IIRC it's called a tile chisel...
        about 1.5 or 2" wide and it has an offset to it...
        chiseling reduces the dust by an extreme margin...
        WOW!!! What a Ride!
        1. frammer52 | Feb 25, 2009 02:52am | #6
          Maybe compared to cutting it, but it still is a mess!>G<
  2. davidmeiland | Feb 25, 2009 01:51am | #3
    I would get a skilsaw with a diamond blade and cut the entire thing into squares, maybe 2' x2', then start popping those off. Beating on it with a hammer does almost nothing.
    1. Hiker | Feb 25, 2009 02:09am | #4
      Ditto what Dave said.  Cut and remove in pieces.  No need to beat it with a sledge
  3. RalphWicklund | Feb 25, 2009 02:57am | #7
    I have the Bosch SDS Max.
    Doing a job right now exactly like yours.
    Wide chisel at a 30 degree angle to the wall pops the old tiles right off and then I go at the mortar straight on, making a grid about 2' by 2' cutting all the way through, including the wire lath. A pry bar pops the chunk off the wall - don't try to catch it - and off to the can it goes. That's a comfortable size for me to carry.
    1. maxspektro | Feb 25, 2009 05:58pm | #8
      Thanks to all for the excellent advice. I think I'll try both options. The saw route is easy since I'm equipped for that. The rotary hammer is attractive because there are some areas where the saw won't fit. My local tool store talked me into a Metabo KHE-D28 with the Bosch HS1465 tile chisel. Back to work...
Picture-Perfect Pergola
