detective help wanted!
frenchy | Posted in General Discussion on April 1, 2006 10:00am
 I’m remodeling my remodel, ?    Yeh!   well anyway I discovered some of the wood is really wet!!
  I need a source for the moisture..
   Let me tell you how the house is built so you can see how impossible this is.
  I am using SIP’s over a timberframe..  Just to review a SIP is a structural panel made with OSB, foam and OSB..  in this case it’s 11 inches thick..   1/2 inch OSB, 10 inches of solid foam, and 1/2 inch OSB..
  I built according to instructions which call for sheetrock on top of the timbers.  then 5 mil poly and then the SIP.. On top of that is ICE and Water shield a glued down covering. On top of that was cedar breather and then Cedar hand split shakes installed with 30 # felt between courses as called for topped with  12 inches of seamless copper.
  This is on a 17/12 pitchroof..
 Now the really wierd part   I mean really wierd!
    The top layer of OSB is bone dry.. dryer than a popcorn fart.  dusty in fact..  it’s the bottom level that has all the moisture.
  If the roof is leaking then somehow water gets past the top layer of OSB without leaving a mark or moving the dust thru a solid  10 inch block of foam   (like a coffee cup foam)  and settles on the lower layer of OSB..
       It’s been three years since the roof was sealed off  and I did the work myself.. The Ice and water shield is overlapped six inches and it over laps at the peak by 1/2 it’s width    Water would have to sneak under the handsplits, slide past the 30 pound felt, go through Ice and water shield, past the top layer of OSB thru a ten inch solid block of foam to get there.  all on a 17/12 pitch roof with solid copper peak!
     My only thoughts are that somehow interior moisture is soaked up by the bottom layer of OSB..
  But how?
 there isn’t a water pipe within 30 feet of the roof  (the plumbing vents on another section of roof.. the rest of the house is bone dry..  Less than 5% moisture   Other roof panels in other parts of the house (where I don’t have a vapor barrier yet)  are bone dry..  top, bottom, sides, etc..
  any thoughts? I’m grasping at straws.
  1. MikeSmith | Apr 01, 2006 10:09pm | #1
    sounds like it may be the same problem they had in Alaska..
     did you gun foam your joints in the sips ?
    here's a  link
    http://www.sips.org/DesktopModules/Articles/ArticlesView.aspx?tabID=0&ItemID=45&mid=11127
    to me it sounds like you have an interior moisture source that you've never found.. and this is just a recurrence of the same problem you  had  with the cellulose in the original attic
    1. frenchy | Apr 02, 2006 04:41pm | #7
      Mike,
          Thanxs, an interior moisture problem?
        As I've said, it's drier than a popcorn fart in the house.  Why would one section of the ceiling be bone dry when three inches over the bottom layer of OSB is soaking wet?
          The only differance between the two areas is one has a poly barrier with sheetrock over it while the other section doesn't..
       NO I didn't gun foam the joints,  I used the adhesive the manufacturer recommended and properly squeezed the joints to gether to get a good seal.. The joints I've cut apart are well bonded and show no gaps.
      Edited 4/2/2006 9:53 am ET by frenchy
  2. calvin | Apr 01, 2006 10:15pm | #2
    Frenchy,  just to clarify.  The visqueen is on the backside of the drywall, under the osb sip panel.  How did you lay the visqueen?  Did you start at the bottom and lap going up or the top going down?  This (top down) might put a possible break in the seal, allowing warmer air to escape up into the space between the visqueen and the osb.
    This idea is a reach at best to help you come up with an answer.
    edit:  Just tried to read Mikes link and for some reason, all the written lines at the link are jumbled on top of themselves and I can't read it very clearly.  Sure is a good idea from what I gather, as the potential source for the moisture.
    Quittin' Time
    Edited 4/1/2006 3:20 pm ET by calvin
    1. MikeSmith | Apr 01, 2006 10:24pm | #3
      calvin.. you can also google on
      sips alaska roofing
      and lot's of sites will pop up
      if i recall.. the problem was every joint allowed moist inner air to  get to the outside layer, which became a condensing surface, then it "rained" back into the bottom of the joint and soaked the bottom layer of osb
      this would also  correspond with frnchy's discussion of cellulose causing moisture problems..
      he has probably got an interior moisture source ( basement / foundation / crawlspace )
      that continuosly pumps moist air into the attic   /  cathedral ceiling area
      the vizqueen moisture barrier is being by-passed
      Edited 4/1/2006 3:28 pm ET by MikeSmith
      1. calvin | Apr 01, 2006 10:29pm | #4
        Thanks.A great place for Information, Comraderie, and a sucker punch.
        Quittin' Time
      2. MikeSmith | Apr 01, 2006 10:44pm | #5
        frenchy... here's a saga of a homeowner   with a sips roof where the edges were not sealed
        check out the guy's triple fracture  from trying to shovel the ice dams
        http://forestmandala.com/index.htmlMike Smith Rhode Island : Design / Build / Repair / Restore
    BillHartmann | Apr 01, 2006 10:53pm | #6
    "Less than 5% moisture"
    That is not the moisture level in the house. You need a humdity guage to measure that.
    That is the moisture level in the WOOD.
    "Other roof panels in other parts of the house (where I don't have a vapor barrier yet) are bone dry.. top, bottom, sides, etc.."
    And that "vapor barrier" is also a water barrier. So you might have the same conditions and it generating a few drops of water, but it can dry out again.
    But with the poly it is being trapped.
    1. frenchy | Apr 02, 2006 04:51pm | #8
      No Bill,
         That is the moisture in the house.. I have one of those sets of gauges with a humidistat.  Honestly the gauge is bottomed out.. if I breath on it it rises so I'm sure it's working.  and it shows 95% humidity during the summer when the windows are open..
        My wife and I both suffer from dryskin caused by the dryness of the house
        I do agree that it could be a moisture problem, with the wood getting damp somehow and the vapor barrier trapping the moisture in.
        BillHartmann | Apr 02, 2006 05:05pm | #9
        That has to be way off.Get a dgital one. Or better, if you run in HVAC people see if you can get one to stop by with there test equipment.
        1. frenchy | Apr 03, 2006 01:08am | #10
          Bill,
           Why does it have to be way off?
            I mean it's drier than a popcorn fart here and wood quickly dries to less than 5% moisture content. In addition both my wife and I have terribly dry skin caused by the dryness..
            The humidity in my breath will quickly cause it to rise and in the summer with the windows open it reads what the weather guy says it is (plus a little since we live on a lake (actually in the middle of a big lake)....
          1. MikeSmith | Apr 03, 2006 01:18am | #11
            frenchy.. did you go to any of those sites i linked ?
            one of them showed an investigation with a thermograph that pretty much told the whole story
            there are energy companies in your area that could do that for youMike Smith Rhode Island : Design / Build / Repair / Restore
