Anyone out there have the Dewalt table saw with the fence out of square with the blade? I have adjusted the fence using the prescribed method in the manual by loosening the two nuts at the back side of the fence but they have reached their limit and the fence is still out of square. I haven’t dropped the saw or abused it in any way but it is useless with the fence out of square. The material binds between the blade and the fence and produces a horrible cut let alone the safety hazard this presents. I was skeptical about the rack and pinion fence when I brought it but it has been fine until now. I hate to throw the saw in the garbage but I really is useless with the fence like this. If I do throw it out it will be the last Dewalt tool I buy. I hate to be winey especially since I do lots of high end work but I expect alot from my tools and Dewalt has not been keeping up with the task anymore. Any input is appeciated.
Listeners write in about shower panels and cordless tools and ask questions about old wiring, air leaks, and gutter covers.
Sometimes if there's not enough side-to-side adjustment in the piece that holds the gear, you have to loosen it even more so that you can move the gear over by one tooth on the rack. Did that make sense?
Bob,
Your fence is not out of square with your blade, rather your blade is out of square with the fence!
No, really.
The back trunnion is stuck a little...happens after making an angle cut. Clean it, lube it, and move it back and forth by pivoting the motor itself (grab the motor instead of using the front handle). Finally, slam it into 90˚ and lock it. Then check parallelism with a combo square. As the machine gets older, you will have to do this more and more. More clean and lube is a sure way to not have to as much.
gk
I don't know how yopu can determine that without seeing his saw. I don't even know which of the 3-4 TS DW makes he is taling about, but his is a problem I had.To begin with, the saw arbor has to be perp to the table slots so the blade is parallel to them.. Then the rack has to be adjusted.I had mine perfect, then DW replaced a motor asssembly for me and I had to start all over again. Harder to get right the next time, because - in part - there were seats cut for the set screws that they wanted to grooove themselves back int. I had to polish that metal a bit first to get a new set.
Dreamcatcher is right on the money.
With the Dewalts you have to reach under the saw and pivot the motor housing rather then pulling the wheel/knob on the front.
First unlatch the fence tabs and try adjusting the allen screws that the fence drops onto.
I have a friend that was deciding betwen this saw and the one I bought (Ryobi w/rolly stand). He bought the DeWalt. He hates the saw for this exact reason. He has become tired of fixing it, and now just adjusts for it when he's cutting. Lot of money to have to expect a bad cut if you ask me.
Edited 11/17/2008 6:25 pm ET by Jed42
Edited 11/17/2008 6:43 pm ET by Jed42
it sounds to me like what fingers said. I'll try to explain that in a little more detail: in the back of the saw there are two small (5mm) phillips or perhaps torx head screws. loosen them a lot then pull the gear down and push the fence left or right, whichever direction it needs to go, then tighten back up those little screws and then follow the directions in the manual with the bigger bolts for the fine adjustment. I hated that saw untill i bought a rosseu table for it. now i like a lot
______________________________________________
--> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
Before you go adjusting the whole saw, try this.
Flip the saw over and blow all the dust out. Look for
the two main pivot points. There are two crevices where
dust collects between the table and the swing arm.
If the saw isn't very clean it will pull out of alignment when you
try and pivot the blade. We just reach under and pivot by grabbing
the blade housing rather then pulling on the knob.
