Diamond Blade on Grinder?
PaulBinCT | Posted in Tools for Home Building on March 4, 2005 05:12am
Need to cut a bunch of holes in plaster and as was recommended here  bought a diamond blade for my PC angle grinder.  Problem is the DW blade I found at the Borg is too thin for the arbor nut on the grinder.  You guys think it’s safe to use a washer to make up the difference or should I hunt down the PC blade?
PaulB
    Sphere | Mar 04, 2005 05:56pm | #1
    Can ya flip the back washer/hub ? On my DW and HF grinders the backing washer has a fatside and a skinny side for thin blades and thick wheels..take a look.
    Restoring, Remodeling, Reclaiming The Quality..
    1. FHB Editor
      JFink | Mar 04, 2005 06:19pm | #2
      What's an HF grinder?
       Justin Fink
      FHB Editorial
        Sphere | Mar 04, 2005 06:24pm | #3
        Sorry, internet shorthand for Harbor Freight, cheap tools that are mostly disposable. The grinder is made by Chicago Electric, which is Tiawanses I think.
        1. FHB Editor
          JFink | Mar 04, 2005 07:16pm | #4
          ah, the good old bright orange tools from Chicago Electric. I've got the laminate trimmer myself.
           Justin Fink
          FHB Editorial
        2. MisterT | Mar 05, 2005 10:28pm | #11
          Chicago is in taiwan!!??
          You'd think the cubs would win more often.
          Mr T
          I can't afford to be affordable anymore
            Sphere | Mar 05, 2005 10:32pm | #12
            They morph..little league in scranton Pa..win evrytime. Go figgure.
    IMERC | Mar 04, 2005 07:54pm | #5
    turn the take up / holding washer over...
    WOW!!!   What a Ride!
      PaulBinCT | Mar 04, 2005 09:04pm | #6
      Nope... but thanks for the suggestions (already tried that ;) )
      Porter Cable seems mystified as well... My grinder is brand new, but my owner's manual varies from the one online inasmuch as it doesn't make mention of a reversible inner flange (mine cannot be reversed) and my inner flange isn't the same as the one shown online.  Curiouser and cursiouser... I'll let you guys know what happens!
      Paul (it only happens to me...)B
      1. Mooney | Mar 04, 2005 10:36pm | #7
        Dewalt and Makita have no such problems .
        I guess this says something for PC grinders.
        Buy a dewalt grinder and it will run the heck out of diamond blades. BUying another grinder is a pretty good idea any way. I have three . They stay hooked up with different suff on them. I use the dewalt for sanding most all the time . It is also the one that runs the diamond blades.
        Edited 3/4/2005 2:41 pm ET by TIMMOONEY52
          AaronRosenthal | Mar 07, 2005 10:12am | #16
          My Hitachi needs a special ring as well when I'm running not only diamond blades but also thin, metal cutting wheels.
          I live with it.Quality repairs for your home.
          AaronR ConstructionVancouver, Canada
        Luka | Mar 05, 2005 10:57pm | #13
        Sounds like you got a grey market, or even a black market tool.
        The person you offend today, may have been your best friend tomorrow It is easy to be friends with someone you always agree with.
          PaulBinCT | Mar 06, 2005 05:26pm | #14
          Nope... Dieeeeerect from PC themselves.  Their customer service people called me back and said that apparently there was a change to the inner flange, and ven though reversing mine will mean it doesn't engage the spindle I should do it (beats me how that makes sense).  I'll try it and see what happens.
  3. arrowpov | Mar 04, 2005 11:24pm | #8
    Dewalt sells an adapter washer for thin blades. I don't see why they won't fit other makes, or other companies should have them. Mine cost about $4.00
      Sphere | Mar 05, 2005 06:56pm | #9
      By golly, yer right! I have one too! I run a chainsaw type doodad in my DW...and needed that part..good call.
  4. Manchild | Mar 05, 2005 07:56pm | #10
    I've run into that probem with them and just make a washer/spacer work. As long as everything says centered you're o.k.
    If you are going to work it real hard it's a good idea to make it so they can't become un-centered with flanges or whatever.
  5. SBerruezo | Mar 07, 2005 08:32am | #15
    I have a Milwaukee grinder, and like the others have said, the outer nut/washer doodad is able to flip over for thin wheels.  Doesn't look like it, but it does do it.
    Young, poor, and eager to learn
