This is a photograph of a recently installed diamond shaped asphalt shingle roof located in Michigan. Does anyone know who manufactures this material? Any leads would be appreciated.
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
Try posting this on breaktime - there are several roofers that hang out there.
Okay, I did a search on the Breaktime forum, as I remembered someone else asking this question. To save you the trouble of searching, I have the pertinent info: they seem to be called T-locks (although someone disagreed with that) and are only (?) available through Sheriff-Goslin (in Kalamazoo, Michigan). Someone else had a link posted, but I din't check it out to see if it was the same, but it is: http://www.classicroof.com/diamonite.htm Hope this helps!
