Difference Between Commercial Roofing and Residential Roofing
Accord construction | Posted in Construction Techniques on June 14, 2012 05:53am
There are two types of roofs which are used on all the buildings that we see around us: commercial and residential. Although it may seem that commercial roofing is done only for businesses or offices and residential roofing is done for apartments and houses, in reality the differences are much more complex than that.
  1. Residential roofing is usually completed by just one hired contractor but commercial roofing usually takes a whole team to complete the job. This is because a commercial roof tends to be larger in terms of square feet than a residential roof.
  2. Commercial roofs need to be made carefully keeping the nature and purpose of the building in mind. For instance, if there is a restaurant in the building then external components like ventilation systems, smoke stacks and pipes will be required. Residential roofs usually do not have such components other than a chimney or two at the most.
  3. Commercial roofs tends to be flat in design to accommodate further changes at a later period, whereas most residential roofs have peaks and other architectural features like roof gardens.
For more detials regarding residential roofing and commercial roofing  spam link removed.
  1. calvin | Jun 14, 2012 06:23am | #1
    There are a couple different type messages here............
    Those that seek out information or help.............
    and those that answer those questions.
    Yours post is another type.  A bunch of words with a link inserted meaning little.
    Congratulations on another shameless spam posting!
    xxPaulCPxx | Jun 14, 2012 01:28pm | #2
    Hey, Accord Construction, how is that lawsuit coming along?  I only heard some wild details and they can't all be true!
    Like, when the crew in OK City you had working on that one guys roof, apparently you thew a big company party on the worksite and passed out tequila like it was Cancune.  I suppose it was the workers fault that they were all tied together instead of properly tied off to the roof - I hoped you fired THAT guy - so when one slipped off they all followed, like some hot drunken mountain climbing disaster movie.  I hope you guys now have insurance, because that homeowner had to apy ALOT of money for that little mishap!
    Also, did you get the issue cleared up where your workers were using pools as toilets?  Sure, everyone might sneek a little pee in the pool while they are swimming, but drop trou dumps in the hottub are pretty impressive!  I could never do that with a bunch of guys cheering me on like that!
    Oh, did you get any clarification from legal as to copying homeowners keys from doorlocks while they are not home?  I know you get them for "Just in case the owner doesn't pay", but I still think  getting some leagalese is a good policy on that.
    Anyway Accord Construction, good luck on your Googl Pagerank!  I hope everyone comes here to read up on your comapany!
  3. florida | Jun 14, 2012 02:40pm | #3
    You did use some words in the proper context but pretty much everything else you said is not only incorrect but stupid.
    evujevich | Jun 14, 2012 08:08pm | #4
    shouldnt this be under 'general discusion?'
    and even if it were that, what are you doing?  must be pg 1 of your textbook.... you look dumb now.
  5. tomwilliam | Feb 12, 2013 07:38am | #5
    Residential roofing construction work can be done with the help  one person, on the other hand commercial roofing construction work takes a whole team of people to do commercial work, because  commercial buildings are much larger than residential.
  6. tomwilliam | Feb 12, 2013 07:38am | #6
  7. tomwilliam | Feb 20, 2013 06:02am | #7
    If you are intrested to install your roof  then go for greencoastconstruction.net because they give you best quality and superior customer service.
    1. calvin | Feb 20, 2013 06:06am | #8
      Tom
      Pretty poor attempt at spam.
  8. jennfiermorgon | Jun 26, 2020 06:46am | #9
    Whether commercial or residential, a roof requires protection in the form of a roof coating.A coat of Liquid Rubber can restore an existing roof to like-new; delaying the need for roof replacement by adding up to 18 to 20 years of guaranteed life protection to your current roof. Liquid Rubber coatings are a fully waterproof solution that completely seal up a roof against mother nature’s destructive forces/elements.
    1. calvin | Jun 26, 2020 06:54am | #10
      Jennifer,
      And butt ugly too, but thank you for leaving out a spam link.
  9. DonnyCreed | Mar 13, 2024 07:59am | #11
    Ensure accuracy and clarity in distinguishing between commercial and residential roofing. Provide practical insights to understand the differences effectively.
