Different trim/base siding question.
blownonfuel | Posted in Construction Techniques on May 5, 2009 06:49am
I was looking at my newest issue of FHB and came across a home on page 30 that I really liked. I like the trim/base of the siding and how it is different from the rest of the siding. Can someone tell me what it looks like they used for the base and small trim between the base and siding? I will be using the Smooth Colonial Hardi for my house and would like a similar look on the base. It looks like they may have use a smooth 12″ piece of hardi or wood for the base?
Does one have to worry about water sitting on top of that small piece of trim and getting behind of the siding? How can that area be water proofed?
I attached a pic.
    Ted W. | May 05, 2009 07:45am | #1
    Ohh... I smell copyright infringement.. =)
    hee heee...  kidding aside, the top of the base looks to be a drip edge, which would be beveled down and have an undercut underneath it to keep the water from running under it. I've replaces a lot of it on old houses, where it went unmaintained and rotted out. Not saying that one would, those I replaced had paint peeling for years on end.
    ~ Ted W ~
    Cheap Tools! - MyToolbox.net
    Meet me at House & Builder!
    Edited 5/5/2009 12:45 am by Ted W.
    1. blownonfuel | May 05, 2009 02:54pm | #3
      Thanks Ted. How is it fastened to the sheathing?
  2. seeyou | May 05, 2009 02:35pm | #2
    http://www.smnv.net/Products/Water%20Table/Water%20Table.htm
    http://www.quittintime.com/      View Image
    1. blownonfuel | May 05, 2009 02:54pm | #4
      Perfect. Thanks Grant.
  3. MikeHennessy | May 05, 2009 02:58pm | #5
    I've done that with 5/4 Azek, cut with a bevel so it slopes out, and with a routed bead under the front edge so it drips right. I used Azek for the trim board below it, and the Tyvek runs under the whole thing, so any water that might blow in drains out at the bottom.
    You can bevel the top edge of the bottom trim board so the water table lays flat on it. Toenail it in to the sheathing, or trim screws, your call.
    Mike Hennessy
    Pittsburgh, PA
    Everything fits, until you put glue on it.
    Edited 5/5/2009 8:02 am ET by MikeHennessy
    1. blownonfuel | May 07, 2009 08:36pm | #6
      Thanks Mike.
