Difficulty Finding a 54″ Bathtub
freematt | Posted in General Discussion on November 27, 2004 09:40am
I’ve been looking for a 54″ bathtub for a small bathroom space. I see that Kohler has a cast iron model in 54 x 30, Eljer has a 54 x 30 in stamped steel and Crane a fiberglass unit in the same size. I was hoping to find a high quality acrylic unit, but no luck so far. I just need a plain tub, no jets or anything fancy like that. In this case the tub is going to sit on a concrete floor so I’m a bit leary of the cast iron or the sheetmetal because I think they’ll be too cold here in our wintery climate. Although, a sheetmetal tub with an insulated backside might be good. The fiberglass unit from Crane has a gelcoat finish which I am skeptical about. As if I wasn’t being picky enough, I’d like also like to find my dream tub in a width of about 34″. Anybody got any ideas? — Matt
There are a thousand hacking at the branches of evil to one who is striking at the root. — Henry David Thoreau
  1. DanT | Nov 27, 2004 10:21pm | #1
    If you go to a plumbing supply house that belongs to a buyers group you can order from about anyone.  In fiberglass you can have modifications made by special order.  If a long lasting finish and quality are the issue then the cast iron is the way to go IMHO.
    Just go with cast, and lay it in a bed of sprayed foam to insulate it.  I have also blown cellulose around them.  The only issue when this is done is not the cold but if you get the water setting to hot initially it takes a fair amount of time for the surface to cool down.  34" wide I think you will be out of luck without a custom unit.  DanT
    NickNukeEm | Nov 27, 2004 10:51pm | #2
    Had to install one last year, and used this:
    http://www.maax.com/en/Products/ProductInfo.aspx?CodeCategory=B&Brand=13&ProductType=1&Product=1119
    It was just Aker Platics then, but it looks as though it has been bought out by Maax.
  3. calvin | Nov 27, 2004 11:30pm | #3
    http://www.aquaglass.com/
    http://www.lascobathware.com/index.htm
    http://www.sterlingplumbing.com/
    Hunt here.
    Quittin' Time
