DILEMMA-Contracted Cedar Shingle Installation
erikneave | Posted in Construction Techniques on November 14, 2011 11:17am
hello.  i am having a contractor put on cedar shingles through a city loan program.  i was on my honeymoon when they started and they are about halfway done with the house now.  i have never installed shingles before but on the things ive seen online i am a bit concerned about the installation.  the 1865 house in wisconsin had old painted cedar shingles and they recomended putting a quarter inch fanfold insullation across the entire house and then installing the shingles on top.  from the little i have read and some common sense, it seems like this will not allow the shingles to dry out and creat some problems down the road.  they have told me they follwed the manufactuerers instructions, but everything i saw said you need something that will let air flow behind the shingle.  when asked about this, the contractor said that the fanfold insullation achieves this purpose.  it sounds a bit fishy to me because i thought insullation would do the opposite.  please offer any help you can, i want to trust that they know what they are doing, but it is stressing me out that i wont really know if this type of installation is quality till a few years down the road when problems show up.
again, they nailed down old, loose shingles, put 1/4” fanfold insullation over whole house, and are using 2” staples to secure the new true north white cedar shingles directly on top of insullation.
thanks in advance for your help.
erik neave
  1. MikeSmith | Nov 14, 2011 01:20pm | #1
    order of magnitude
    between  what  they  are  doing  and  what  should  be  done
    but.......  your  budget  may not  afford  what  should  be  done
    1st
    all  the  old  shingles  should be stripped  to the  sheathing
    then  the  flashings  around  trim , windows  , doors   should  be  replaced
    house  wrapped  with  either  15 lb  or  30  felt
    all  the trim, casings, sills... should  be  scraped  in accordance  with   the  RRP  rules   of  the EPA
    your  house  has  lead  paint  on it... i  guarantee
    then  the  trim  should  be  primed  and  painted...  or  they  can  wrap  the  trim  in aluminum if  that  is  your  cup of  tea
    your  painted  cedar  shingles  have  lead  paint  on them...  but  they  can  be   disposed of.
    next.....  ready   to  shingle
    1st...  you  are  used  to a painted  shingle,  which  to me  sounds  like a  very  formal  look
    if  you  are  going to  use a  natural , no  finish,   white   cedar shingle,  you  may  or  may  not  like  the  final  appearance
    white  cedars  are  not  a very  stable  shingle... especially  on the  south  side  they  love  to  curl..  often  look  like  potatoe  chips  were  used  instead  of  shingles... and  being  a natural material,  they will color  to  a color  of their  own  choosing, which   will NOT  be  uniform
    if   you  want  a uniform  color  you  need  to  use  a  factory finished   or  site- dipped  shingle,  either  of   these  will also  help  with  the curling
    a  common  source   of  factory  finished  shingles  is  Maibec
    or......  maybe you  don't  really  have  a  white  cedar  shingle  anyways... if  they  are   painted,  chances  are  pretty  good  that  they are  really  Red Cedar  shingles
    a  couple  things  will  help  in  this  discussion... what   is  the exposure  on  your  existing  siding ?
    is  it  5"    .... 6".......  8"....... 10"  ?????
    if  this  contractor  does  what   he's  saying .... he  is going  to  bury  all  your   trim...   he's  a  hack
    who  wrote  your  specs ?   where did  you  get  this  guy from ?
  2. MikeSmith | Nov 14, 2011 01:22pm | #2
    order of magnitude
    or  perhaps  i'm  being  too  harsh.. doesn't  sound  like  you  are  going to get  a very  good   job
    1. erikneave | Nov 14, 2011 02:18pm | #3
      further info
      thank you mike for your response.  i am kind of freaking out at this point because they are nailing in shingles as we speak.  the company was one of two that bid through a lead abatement program through my city.  they are called shefchik energy services from green bay wisconsin.  the reason they are doing this is because of the lead paint.  honestly, the windows they put in look pretty good.  they built out the trim and are covering it with aluminum (not my first choice, but i was talked into it)  i do know the look of white cedar gone natural grey.  i like it.  we just spent our honeymoon on the east coast and saw a bunch of naturally weatherd cedar and it is definitely our cup of tea.  the thing i am really concerned about is whether or not moisture is going to get trapped and not allow the shingles to dry out with the way they are doing things.  could you please speak to that?  they told me leaving the old shingles on would be fine.  maybe that is because there is no sheathing underneath (i checked)  the exsisting siding is put on over even older wood clapboard siding.  the other thing i noticed is that the staples in some cases are countersinking a little bit.  they said it wont be a problem, but things online i read said it will be.  is that a big deal?
      realistically, how long will a job done like this hold up compared to the way you propose and what are the major concerns.   rot?
      if you dont mind giving some more advice, i would be greatly appreciative.
      erik
      also, do i have any rights to tell them to do it over/better?  im not sure how to approach this....
      1. MikeSmith | Nov 14, 2011 05:31pm | #4
        arrrgghhh
        Erik...  you're  there, i'm here..
        since this  is  a  lead -abatement  job,  you're   covered as  far  as  that  goes....
        and   really ?   no  sheathing... just  clapboards  , huh ?
        short  of  taking  it down to  the studs, you're   kinda  stuck.
        you  have  now  given  me  more  information  than  your  original  post:
        it  sounds  like  you  have  studs,  no  sheathing,  clapboards, existing  white cedar  shingles,   a  fan-fold   foam  layer,  and  new  white  cedar  shingles.................
        they  also  left  the existing  window  jambs  and  sill, interior  casing,  exterior  casing....  and  installed  replacement  windows,  since  the  old  sash were covered with  lead  paint   and  the  old  clapboards  and  the  old WC   shingles   are  covered  with  lead  paint
        the  fan-fold  foam  is  not  a vapor barrier, it  allows  moisture  vapor to  move thru it.. it's  purpose  is  to  attempt  to  level the layer  of  wc  shingles underneath
        realistically.... i don't  know  what  other  choices  you  have  other than  choosing  a different  siding  ...  like fiber  cement , or  vinyl.. or  red cedar,  etc
        this  job  is  not  really about  new  siding, it  is really about  lead-abatement....
        the  only caveat  i  have at  this  point  is   wondering  how  they  intend  to flash  the siding  and  the trim...
        moisture  within the house  can  dry to the interior  and  to  the exterior  (  in season )....
        the only  water  you  have  to worry about  is  bulk water  and  rainwater.... the siding  and  flashing  is  supposed  to handle  that
        your  contractor  has  to  have  a plan  for  his  flashing / trim wrapping  that  solves the threat  of  leaks
        if  you  liked  the  soft grey  look  of  white  cedar  (  the romantic  "Cape Cod  look " ).....  use a  mix  of  bleaching  oil  and  silver  grey.. Cabot's  makes  a  good  product.....  this  will weather  to the look  you  want
        leaving it up to  nature  will give  you  other  colors  and stains  unlike  your   memory  of  the houses   back  east
        as  to  leaks    and   flashing..  the devil is  in the details.. every  horizontal  ledge,  every  vertical  seam,  every  window .. every  door.. every  place  the siding  meets  a  roof
      2. Piffin | Nov 16, 2011 05:37pm | #10
        " the other thing i noticed
        " the other thing i noticed is that the staples in some cases are countersinking a little bit."
        That is because they are using stapels. It is a "feature" of hack work. The cedar buearau is very specific that nail head mujst NOT penetrate the wood fibre. That shortens the lifespan of an installation.
        With all the layering you have going on, you have one hack job over top of another.
        Unfortunately tht is part and parcel with most of these govt run "programs"
  3. erikneave | Nov 15, 2011 08:54am | #5
    i want to thank both of you very much for taking the time to share your thoughts.  i am meeting with the head contractor today to discuss some of my concerns.  it will be helpful to bring the knowledge you have offered.  like you said, there may not be much else to do about it at this point but every bit of direction helps.
    it looks like they are going around the whole roof line overhang with aluminum flashing coming under the uppermost shingles.  i cant realy tell about around the windows since it was mostly done by the time i got there.
    the more detailed info on what fanfold will actually do and not do was also helpful.
    thanks
    erik neave
    1. MikeSmith | Nov 15, 2011 09:10am | #6
      so...
      what's the exposure  on your  shingles ?
      what   size  shingles  are  they installing  ?
      1. calvin | Nov 15, 2011 07:48pm | #7
        Like pulling teeth Mike
        Keep at it.
        1. MikeSmith | Nov 15, 2011 09:35pm | #8
          ain't it grand ?
  4. Piffin | Nov 16, 2011 05:31pm | #9
    No, they don't have a clue
    "they nailed down old, loose shingles, put 1/4'' fanfold insullation over whole house, and are using 2'' staples to secure"
    They should start by tearing off the old shingles
    The fanfold is OK but requires a breather between it and cedars
    Staples are terrible for cedars
    1. erikneave | Nov 18, 2011 05:45pm | #12
      what is the worst thing about using the staples?
      the exposure is hard to tell... some are around 5'' and some more like 8"  the rows arent really even.  and the total shingle length is about 16''
      i couldnt find a tag on the bundle.  maybe it was already removed...
      erik
      1. Piffin | Nov 18, 2011 08:19pm | #13
        Staples break the grain of the wood so it will niot hold as well. Worse on roofs than on siding, but either will have shorter life span with staples.
        Exposures should be consistent and even, nio more than 6" for a 16-18" cedar
        Variance like that - this contractor is a cdertified hack
      2. MikeSmith | Nov 18, 2011 09:41pm | #14
        the rows are supposed to be
        even...and  planned so they  hit  features...you  lay out  with  a story pole...so you can hit   arcitectural features...like  the  tops  of  windows...or  window  sills
        a 16" shingle  should  have a  maximum exposure  of  5 1/2 "....not   8"
        ( < 1/3  of  the  shingle  length )
        the  courses should vary  by  more than 1/2 "  from  course to course.....we  like to keep them within 1/4"
        it  goes without saying  that the  have to be level all the way around the  house
        1. Piffin | Nov 19, 2011 01:45pm | #15
          Hey Mike - LOL
          "goes without saying  that the  have to be level all the way around the  house"
          So you've seen some of those that look like run by a drunken sailor down that way too, eh?
          No offense meant to sailors of ourse
          1. MikeSmith | Nov 19, 2011 04:31pm | #16
            you know
            we  used  to  set up  a transit  and  strike  a level  line all around  the  house   for  "gospel"
            nowadays  we  use  our  $99  laser,  set  up on each floor, swing  the compass  ,  drive  a  few  nails
            and  we  have  a  "gospel line"  for  each  floor.. ain't  technology  great ?
            last time  i had  words  with  one  of  my  guys was  about  20 years  ago....  they  had  shingled  a new  addition... missed  the  old  coursing  by  about  3/4"  at  the meeting  point
            he  insisted  it  wasn't  his  fault,  he  had  used  a  level.. i  point ed  our to  him the difference  in  coursing....and  the  idea of " using  a level  and  being  level
          2. DanH | Nov 19, 2011 05:49pm | #17
            I used a water level when we resided.  A laser (which didn't really exist at the time) can't see around corners.
          3. Piffin | Nov 19, 2011 06:24pm | #18
            The places I work on are too old to use a level of any kind for siding. You have to go dot-to-dot so it looks level
          4. MikeSmith | Nov 19, 2011 07:16pm | #19
            trompe l'oile
            (sic )...fool the eye...
            perspective....parallel...hollywood side
            you drive by something and say ' geesh...couldn't they see that ?"
  5. Piffin | Nov 16, 2011 05:39pm | #11
    "How well the shingles will
    "How well the shingles will work out on the fanfold is hard to say."
    It is only hard to say for someone who hasn't dealt much with cedars
    The only way i will perfoirm well is if the climate is dry and there is a larger roof overhang and plenty of ttrees to shelter against wind driven rain
  6. makita888 | Nov 20, 2011 07:54am | #20
    hack
    As Mike Smith said HACK. There is no way this job could be right. The build up would look ridiculous. Also included in what Mike said about stripping the old siding the sheathing should be re nailed, something I think very few contractors due after removing siding and roofing. A solid underlayment is the secret to any good job!
    1. makita888 | Nov 20, 2011 08:11am | #21
      didnot read entire post
      Sorry did not realize there was no sheathing., but multiple layers are a terrible idea as our staples. I live on the northshore of Ma.
      and lived on Nantucket for several years where everthing was cedar shingles. Staples were always a problem due to lack of a big enough stagger on siding as well as breaking the grain. We use ring shanked galvy or stainless and never exceed 5" exposure. Also splines on protrusions are critical. We also make benchmarks and story poles to ensure hitting tops and bottoms of windows, simple math. Old houses may require stringing and pinning the line in more than one place to "look level" when the house windows are out of level
