Dimmer switch: control a fan?
edwardh1 | Posted in Energy, Heating & Insulation on January 11, 2004 02:55am
Can you use a regular wall dimmer switch that is designed for lighting to control a small motor, like a 115 volt .6 amp fasco fan in a fireplace?
the fan makes a lot of noise and i wanted to slow it down – the later models of these fireplaces have rheostat / dimmer “switches” to control the fan
  1. Stuart | Jan 11, 2004 04:35am | #1
    Unfortunately, no.  A regular light dimmer decreases the amplitude of the AC voltage but does not change the 60 cycles per second frequency, which is what controls the speed of the motor.
  2. OneofmanyBobs | Jan 12, 2004 02:44pm | #2
    You'd have to replace the motor with an AC/DC variety to use a speed control.  This is not a good choice because they have brushes and would eventually need replacement.  Also the wrong speed; too fast.  You may be able to hunt around and find a 2-speed AC motor the same size.  Maybe 900/1800 RPM.  This would just use a switch, not a dimmer.
  3. tenpenny | Jan 12, 2004 06:00pm | #3
    Check whatever literature you have from the fireplace; in my experience, almost all of them are designed for this; however, make sure the dimmer/speed control is the kind you'd use for a ceiling fan or kitchen fan.  No big problem.
    1. edwardh1 | Jan 12, 2004 06:35pm | #4
      i should have thought of that
      will do
    rjw | Jan 12, 2004 11:42pm | #5
    Yes, it will control the speed, and no, you shouldn't use it to do that.
    _______________________
    Tool Donations Sought
    I'm matching tool donors to a church mission to Haiti - we're shipping a bus converted to a medical facility in (now it looks like) April and can fill it with clothes, tools and all sorts of stuff needed in that poorest of all countries. A few hand tools or power tools can provide a livelihood for an otherwise destitute family. Please email me if you have tools to donate.
    Thanks to Jeff and David and Jim and Rich and Steven and Mark and Jason and Shep and Jen and Mike and Joe for their offers!
    The first donation just arrived! Thanks and God bless!
  5. renosteinke | Jan 13, 2004 03:03am | #6
       If you look closely at the dimmers in the store, you will see that there are two types: for motors, and for lights.
       The ones for lights typically start the light at its' lowest setting, then gradually increase to full brightness.
       Some for motors work in a similar manner, but start the motor at full power, then reduce the speed. A more common type these days lets you select one of three speeds. These are "better," in that they are less likely to either cause the motor to hum, or to generate radio noise.
