Direct Vent Fireplace
| Posted in Energy, Heating & Insulation on December 19, 2007 02:40am
I am building a new family room addition with a direct vent fireplace (Heat&Glo 6000). The building inspector noticed the fireplace. I mentioned I was having it installed and I wanted to insulate the wall cavity behind the fireplace. He said to remove the kraft backing and to install a fire shield/stop such as thermaply  or thermapan (sp?) 1/8 inch thick. I guess this would be in place a drywall. Does anyone know what he is referring to because I cannot find anything worthwhile using Google searches.
  1. JLazaro317 | Dec 19, 2007 03:33am | #1
    Here is a link for Thermo Ply:
    http://www.covalencecoatedproducts.com/en-US/products/Thermo-Ply/content.aspx
    We use the HNG 6000 quite a bit. We always install after insulation. We have the insulation contractor fill the roof and stud cavities full of foam and leave a very generous airspace.
    John
    J.R. Lazaro Builders, Inc.
    Indianapolis, In.
    1. p2monaco | Dec 19, 2007 05:55am | #3
      What is special about the thermo-ply? Will it provide some sort of heat/fire shield? Or does it just keep the insulation tucked in?
      What do you use between the insulation and the fireplace?
      1. JLazaro317 | Dec 19, 2007 06:20am | #4
        Honestly, I'm not familiar with thermoply. I just found the link since you were inquiring. It is just a thermal barrier, I believe I read that it will give you a 1 hour rating.
        Between the insulation and the fireplace we just use a generous air gap. If you build the box too tight, then you need a barrier such as thermoply.John
        Indianapolis, In.
      2. Grott | Dec 19, 2007 08:23pm | #5
        I'm not sure about your instilation but we have the chase DW'ed or sheathed to insure the insulation will never fall onto the heater or imto the airspace.Garett
  2. bhackford | Dec 19, 2007 03:58am | #2
    We do not need to install drywall just make sure air space is good as required.
    I have done several vermont castings fireplaces.
