is there such a thing as a direct vent oil fired furnace? i mean like the 90 plus gas furnaces that vent thru PVC. something that would noy require a masonry chimney
![](https://images.finehomebuilding.com/app/uploads/2024/07/10133441/01232535-cali-valley-heads-east-feature-Large-thumb-16x9.jpeg)
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
Here's a boiler that's direct vent
http://www.burnham.com/residential/51210.cfm
(see features, below)
If they can make a boiler, I'm sure there is a direct vent forced air gas furnace.
I thought about getting a direct vent oil boiler. I didn't. Oil too stinky for me to have the exhaust at ground level ....
Oh yeah, by the way, you don't need a masonary furnace. In most cases double walled will do. I put in a super duper insulated chimney, and my inspector thought I was nuts to spend the money.
Edited 2/4/2003 1:52:59 PM ET by Piccioni
Type L, not type B_______________________
"I may have said the same thing before... But my explanation, I am sure, will always be different." Oscar Wilde
Do you mean type L double walled? I searched and search and couldnt get a straight answer as to exactly what type was ok. That was one reason for the overkill.
Well, now I know...
Yeah - type L for oil fired, B-vent (type B0 is only for gas fired._______________________
