disappearing door
daddoo | Posted in Construction Techniques on June 16, 2004 12:38pm
My client wanted a closet door that blends right in with the wall; a flat door with no casing and no lockset. When its closed, only the hinges show. A H.D. touch latch holds it shut. But the joint between the door jamb and the drywall keeps cracking. Anybody got a better way to join the two?
When all else fails, use duct tape!
  1. gdavis62 | Jun 16, 2004 01:08am | #1
    If the door isn't too heavy, you might consider hinging it with euro cup-style hinges.  I can envision a 1x4 screwed to the jamb face, with its one edge flush to the line of the back of the door.  A half dozen hinges can swing it from there, and the arrangement looks in section like a full overlay cabinet door.
    I did a linen cabinet door that way.  The face of the built-in floor to ceiling cab was done in 1x4 edge and centerbead pine, and I made a door of the same material, with its beading detail lining up to the small surround at top, bottom, and sides.
  2. seeyou | Jun 16, 2004 01:17am | #2
    I bought several disappearing doors about 10 years ago, but I set them down in the shop somewhere and I haven't been able to find them since.
  3. SEBDESN | Jun 16, 2004 02:10am | #3
    All you are concerned with is the crack in the drywall between jamb and wall ?? I assume something is moving. (Sherlock strikes again?). Scrape off all the drywall mud etc off down to the solid wood and use epoxy and glass cloth to make the two surfaces one,then mud over and finish. Or maybe tape and  setting mud would work....
  4. DanH | Jun 16, 2004 03:17am | #4
    The jamb should have been trimmed flush with the framing so the wallboard could cover it.
    Use SOSS hinges, and nothing at all with show.
    artacoma | Jun 16, 2004 03:18am | #5
    Did it once, used 1/2" jamb stock and installed the jambs before drywall and had the cornerbead wrap around the jamb. It's held up for 6 yrs now.............Rik............
