Discolored around bathroom sink drain – can I install a drain with a larger collar?
MichDoug | Posted in General Discussion on May 20, 2012 07:49am
Hello All,
I have a molded bathroom vanity top with sink that is in good shape except that there is discoloration around the drain.  Is there a drain that has a larger surround/collar to hide this?  I would prefer not to replace the vanity top, especially since it is a non-standard 42 inch width.
Thanks in advance!  Great info on here.
  1. DanH | May 21, 2012 12:06am | #1
    All you can do is look and see if you can find something.
    But if the top is Corian or another solid surface material you can sand away the stains.  And if it isn't (but is instead the plastic over flakeboard stuff), it's not worth fooling with.
  2. calvin | May 21, 2012 06:17am | #2
    doug
    if this top is cultured marble the stain will continue to enlarge and is not sandable.
    I know of no drain collar much wider than what you probably have.
  3. Natineah | Aug 21, 2012 09:09pm | #3
    If it's an acrylic sink, you can remove the discoloration using non-abrasive scrub pad, baking soda, borax powder, and diluted liquid bleach.
Mortar for Old Masonry
