Dishwasher and Disposal on same circuit
edwardh1 | Posted in Energy, Heating & Insulation on November 10, 2009 05:42am
Is it a problem? Not from a code or circuit loading view (all my homes seem built this way) but is there any issue with the disposal motor putting “noise” into the more modern dishwasher control boards and causing a dishwasher function problem??
Do I need any type filter on the disposal?
  1. renosteinke | Nov 10, 2009 05:55am | #1
    I am not aware of an such issues.
  2. restorationday | Nov 10, 2009 07:05am | #2
    Rarely have I seen it done the other way.
  3. TooManyToys | Nov 10, 2009 03:51pm | #3
    When I installed our disposal here in NJ 20 years ago it had to be on it's own circuit.
  4. Scott | Nov 11, 2009 01:33am | #4
    Really? It's a code issue here.
    DW is a motor and heating load = high current. Our code requires a dedicated circuit.
    In fact, I read this morning that the GD requires it's own circuit too, but no reason was provided. I'm surprised by this because unless it's a massive GD, I wouldn't think it would pull much current.
    Scott.
    1. edwardh1 | Nov 11, 2009 02:07am | #5
      Thanks, understand, my GD is small 1/3 HP maybe.
      BillHartmann | Nov 11, 2009 02:53am | #7
      Well in the US a dedicated appliance can share a circuit with other if it draws no more than 50% of the circuit rating.Now my mid level DW is rated at 9 amp max And in practice much less since I don't use the heater.And a small GD would probably be less than 10 amps.But a 5/8 or 3/4 HP would be around 12 amps. And by code could not.But in practice GD run only seconds at a time. While it might not meet current code or practices there are millions of homes with GD and DW on the same circuit and have not had a problem for years..
      1. Scott | Nov 11, 2009 07:26am | #8
        >>>While it might not meet current code or practices there are millions of homes with GD and DW on the same circuit and have not had a problem for years.Yeah, and the other factor is that regular residential branch circuits in Canada are no more than 15A - 14 guage, so it's not surprising that the code calls for a dedicated circuit for a dishwasher (although the author I was reading today strongly recommended 20A - 12 guage, but again following the code requirement of a dedicated circuit. Might as well give that load all it wants). From what I understand, you guys regularly use 20A - 12 guage for branch circuits, which gives a bit more headroom for a second load. Is that right?Scott.
          BillHartmann | Nov 11, 2009 08:07am | #9
          "From what I understand, you guys regularly use 20A - 12 guage for branch circuits, which gives a bit more headroom for a second load. Is that right?"Yes..
        2. gfretwell | Nov 11, 2009 09:36am | #10
          We also see a lot of these dish washer and disposal receptacles run with a shared neutral multiwire circuit that you Great White North guys are used to seeing in kitchens.
          1. Scott | Nov 11, 2009 08:56pm | #11
            >>>a shared neutral multiwire circuitThat makes eminent sense. Both circuits are running to the exact same spot; might as well share a neutral and save some bucks.
  5. JTC1 | Nov 11, 2009 02:39am | #6
    Here for any type of major kitchen remodel, we have to provide a separate circuit for dishwasher and disposer. Usually 20a for DW, 15a for GD
    Replace existing - OK with whatever is in place.
    Don't know about noise and control boards.....
    Jim
  6. barmil | Nov 16, 2009 05:55am | #12
    My dishwasher and disposal are on the same 20 amp circuit. May be a code violation, but I never run them both at the same time, anyway. I don't happen to have enough slots on my breaker box to pamper these appliances with their own circuits. The previous owner had everything in the kitchen on a single 15 amp fuse, which she changed to a 30 amp because the 15 amp kept blowing. I think I saved the house by buying it from her.
  7. RippySkippy | Nov 16, 2009 06:07pm | #13
    Around here, we can run a 12-3 to the DW and GD, share the neutral with a 20 amp twin breaker. The code officials give it the thumbs up, and suggest it. My house is that way and we've never had a problem.
