Dishwasher drain
| Posted in General Discussion on October 10, 2003 08:39am
A plumber told me that in my town the plumbing inspectors want the dishwasher drain line tied in right above the trap under the sink, even when there is a disposal with a dishwasher drain port.  Why would they want this done?  I would think it would be better for the HO and the city to have the D/W drain to the disposal to reduce the possibility of large food chunks going down the drain and causing a blockage.
    IMERC | Oct 10, 2003 10:35am | #1
    The DW soap will eat your garbage diposal.
  2. IronHelix | Oct 10, 2003 02:35pm | #2
    I think the main concern is the possibility of cross contamination if the DW hose would back siphon a full load of fermented food stuff out of the disposal into the dishwasher.
    Rings true for older models of DW....but air gaps and one way valves in the new DW's have cured that situation.
    Our local plumbers do not to use a DW tailpiece as it can flood the sink basin that it is attached to and cross contaminate that area of the food prepearion area.
    Current practice also mandates that new installation for Disposal is trapped directly to the sewer line and separately from the sink drain. thus preventing backup into the sink basin.  The DW is connected to the Garbage disposal with an Air Gap or in line backflow preventer.
    The soap thing is probably applicable to cheaply/poorly cast models of GD.....most of of the GD's I've seen die of motor failure.   Some folks also use drain cleaners in disposals....sure shortens the lifespan.
    .....................Iron Helix
  3. EricS | Oct 10, 2003 03:14pm | #3
    I believe that that a good quality DW macerates food particles such that plumbing above the trap as your local inspectors "require" would be OK as long as you also looped the DW drain line to the bottom of the countertop (and secured it there) and then on to the above trap connection.
    I had an air gap fixture in my first house 25 yrs ago that plugged up about once a month - a nuisance item.  Just yesterday my neighbor was complaining about her DW not draining and I found her air gap fixture plugged.  This is an older (12 yrs) DW.  She claimed that "a little bit of water" always leaked from the fixture - and her kitchen floor shows it.  Well, I by-passed her air gap and went directly to the disposer with the loop previously described.  To the best of my knowledge, this meets code in our county.
    Eric S.
  • Fine Homebuilding's Author Guidelines
