Dishwasher draining
cwcjr09 | Posted in General Discussion on February 23, 2011 06:49am
I have a customer with a whirlpool dishwasher that, after draining, still has a decent amount of water in the bottom. I know it is normal for a small amount of water top remain, usually enough to cover the pump module. But this appears to be a little more and they are complaining that in the summer they get mosquitos in the dishwasher because of it. The hose does not appear top be blocked as the dishwasher is draining. So I just need to address the little bit of standing water in the bottom. Not sure what to do given there is no real blockage and the pump works fine. Any ideas?
  1. calvin | Feb 23, 2011 06:57am | #1
    Drain hose run.
    Is there anything unusual about the route of the drain hose?  Long horizontal b/4 going up and back down to the drain connection at the sink?   Or no run up high b/4 connecting to the drain?
    Like a sump pump, any water not evacuated in the line runs back.
    1. DaveRicheson | Feb 23, 2011 04:18pm | #5
      Vision.
      This may be inappropriate, so I saying up front, it is just some lighted hearted fun.
      I'm picturing a dishwasher setting on a porch beside a washing machine and a old wooden chair.
      Wouldn't be that unussual in eastern KY.
      Just trying to figure out how mosquitoes ar getting a dishwasher :)
      1. calvin | Feb 23, 2011 06:40pm | #6
        Would that be your neck of the woods?
        or are you dissing the other end of the state?
        I didn't think at the time, but I'm sure it sounds sensible that these units have check valves rather than relying on a high loop.  And if it's damaged or stuck-most probably could lead to a swamp.
        But, mosquito's breeding?   That sounds odd-fruitflies epidemic sure, around the compost pail-but mosquito's..................
        Proves you never have heard it all.
  2. fingers | Feb 23, 2011 07:05am | #2
    They could try aerial spraying for mosquito abatement.
  3. DanH | Feb 23, 2011 07:19am | #3
    Yeah, how long is the drain hose, and how is it routed?  If there's no high loop then what you could have is water flowing back from the sink drain into the DW.
    kurt99 | Feb 23, 2011 10:33am | #4
    Check Valve
    The last dishwasher I worked on, a GE, had a little rubber flapper/check valve at the outlet of the pump where the drain hose attaches.  I won't guarantee that Whirlpool does the same, but I would look for such a valve and see if it is crudded up, worn, or damaged.
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
