I’m thinking about getting a laser measure and leaning toward the D2. I do quite a bit of interior trim and I’m sure it will be fine there, but how well do they work outdoors?
The FHB podcast crew chats about whether or not coil stock on fascia and rake trim is necessary.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
I just got the D3 the other day. So I've only been messing with it so far.
But as long as it's not bright sun, it seems to be fine outside. And the device itself will function in bright sun, you'll just have trouble identifying the target while aiming. Interior-wise I think you'll find it to be terrific.
I went through the live.com search to save 30% when I bought it on ebay. The discount changes. Today it's 25%.
I have been using the stabila, and it has been great. Just finished a built in today and used it several times. It's been a life saver when working solo on some framing chores. Not cheap, though.
"The nearest thing to eternal life we will ever see on this earth is a governmental program" -Ronald Reagan
