Do twisted galv nails suck or is it me?
geoffhazel | Posted in Construction Techniques on October 27, 2008 08:14am
I had some 3/4 plywood to nail down on an exterior deck and since it wasn’t a huge area, I decided to use nails vs. screws. I found some twisted galv 8d nails at HD, labelled “decking” and decided to give them a try.
Either I’ve lost all my nailing skill, or these nails are just bad, because I had a dickens of a time getting them into the wood. About every 10th nail would go in to within a half-inch and then bend over. Once bent, they would NOT go the rest of the way in (or come out) and I had to break them off. Dang, I hate that. Good thing the deck was getting painted.
The joists below were old fir 2×10, might have been a bit on the “hard” side, but it was weird that they would consistently go within a half inch of the goal and then just bend over.
Was it something I was doing or are these just horrible nails?
    IMERC | Oct 27, 2008 08:21am | #1
    1. they're from home desperate...
    2. WTB the manufacture is from off shore
    3. they are junk...
    4. HD's products tend to sabotage your work...
    5. see associated thread and sublinks.... http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=111952.1
    6. the rest of yur question is a matter of opinion and conjecture...
    WOW!!! What a Ride!
    Edited 10/27/2008 1:25 am by IMERC
    1. geoffhazel | Oct 27, 2008 09:20am | #2
      IMERC wrote: # they're from home desperate...
      # WTB the manufacture is from off shore
      # they are junk...
      # HD's products tend to sabotage your work.Yea, that's kinda what I was thinking....
    2. Waters | Oct 28, 2008 05:25am | #18
      u crak me up.
        IMERC | Oct 28, 2008 05:34am | #19
        thank you....
        1. webby | Oct 28, 2008 05:45am | #20
          Sorry should have given a little more info.
          We were framing a 4 /12 pitch shed roof for a porch. Used 2x4 for the rafter iirc. 'Bout a 8 foot run.
          Boss sent me up with them to nail the joist hangers on after toe nailing (w/gun 16 spirals) for good measure. I figured we would use hanger nails but he handed me the 8d galv   spirals and I figured he wanted to use them because we were nailing into old clapboard siding (in good shape).
          Inspectors somehow don't seem to visit our jobs very often. Only when he gets fined which is 25 dollars for not pulling a permit at least that is what he said.
          Reading between the lines is required here. This is the pay with company check but no with holding no WC no SS, no insurance etc. guy.
          Webby
          Edited 10/27/2008 10:52 pm ET by webby
          Edited 10/27/2008 11:18 pm ET by webby
          1. webby | Oct 28, 2008 05:49am | #21
            Lately I have also had a heck of a time with buttoncap nails. I don't know if it was the osb or what but I did see some with a slight bend in the box.Webby
            IMERC | Oct 28, 2008 05:55am | #22
            check country of origin....
          3. webby | Oct 28, 2008 06:20am | #25
            Yeah, I will, I didn't think to look at the time. Proabably not domestic nor even a fine import.Webby
          4. alanj | Nov 01, 2008 06:39am | #26
            Maybe you never worked with old fir before.That #### is like iron.Much of the older framing up here is D fir and it's a bitsh.Many customers like me to re-use studs and such. Snaps heads off good screws, splinters when you air nail. Scarey stuff and tho' I like to recycle, I discourage reusing fir.
          5. geoffhazel | Nov 01, 2008 08:20pm | #28
            Regarding reusing fir:Many many years ago I went briefly to a community college in their 'builders' program, and part of the program was to build a house. Fine, you'd learn a lot. But the catch was it would be with as much recycled material as possible, and that included recycled studs. I dropped out before I got to that part, but talked later with someone who completed it, and asked him how it went. "Miserable" he said. "Those old studs were the worst!"
  2. muffy1 | Oct 27, 2008 01:12pm | #3
    When they are made in China  need to drill pilot holes!
    1. webby | Oct 27, 2008 02:50pm | #4
      I had similar results nailing with some spiral galvies. What reaalllyyy sucked is I was tasked with using them to attach joist hangers.Webby
      1. GRCourter | Oct 27, 2008 03:24pm | #5
        Why twisted with joists hangers, never heard of this before, I have seen it but never heard anyone say they used them.
          IMERC | Oct 27, 2008 04:59pm | #6
          some see it as a hold better deal...
          1. rasconc | Oct 27, 2008 05:03pm | #7
            Probably, but I would bet the shear value is less.  Do not recall any Simpson conversion for spirals but it may be there.For those who have fought for it Freedom has a flavor the protected will never know.
          2. GRCourter | Oct 27, 2008 05:07pm | #9
            Hold which way?  I believe that the purpose of the hanger, strap, clip is to support and this is why the shear strength is the important factor in hangers.  I could see if you were using 12d spirial nails for framing, or 8d for sheating, these may require holding power.  But hangers, I don't see the purpose other than to lessen the support of the hanger.
            IMERC | Oct 27, 2008 05:43pm | #11
            some tend to think in terms of fastener pull out rather than shear when comes to hanger type hardware....
            and here you'd fail if yur using other than rated fasteners...
            jarhead2 | Oct 28, 2008 06:03am | #23
            I won't even part HD doors..........
            “Some people wonder all their lives if they've made a difference. The Marines don't have that problem.”                Reagan....
        2. Huntdoctor | Oct 28, 2008 03:59am | #15
          And won't even pass code in my area.
          Maybe I shoulda read all the post 1st huh?
          O well, still wont pass code.Russell
          "Welcome to my world"
          Edited 10/27/2008 9:01 pm ET by Huntdoctor
      2. AitchKay | Oct 27, 2008 05:07pm | #8
        That's a good way to get your job flunked. My inspectors are really picky about using rated nails!AitchKay
  3. user-267213 | Oct 27, 2008 05:18pm | #10
    And when they bend all the galvanizing flakes off...
  4. Jed42 | Oct 28, 2008 02:52am | #12
    The answer to the original question - without reading any of the posts - is YES, THEY SUUUUUUUUUUUUUCK!!
    No Coffee No Workee!
    1. shellbuilder | Oct 28, 2008 03:07am | #13
      2nd the suck part
    2. geoffhazel | Oct 28, 2008 05:22am | #17
      Glad to read all the replies. I didn't think I'd lost the ability to nail an 8d nail sraight. I should'a used the HD galv nails, a bit thicker, at the least, even if they came fro the same source.
  5. Junkman001 | Oct 28, 2008 03:47am | #14
    Much of HD fasteners are junk.
    Mike
    Insert initially amusing but ultimately annoying catch phrase here.
  6. toolbear | Oct 28, 2008 04:32am | #16
    Used to bitch about the Korean nail mills. Little did we know how good we had it.
    I have seen 16d box HDG coming out of the carton with a delicate pre-bent arc on them. This usually becomes a right angle when I hit the nail.
    The ToolBear
    "You can't save the Earth unless you are willing to make other people sacrifice." Dogbert
  7. DavidxDoud | Oct 28, 2008 06:11am | #24
    I've used boxes of them over the years and they can be great nails - I keep 8d-10d-12d-16d-20d in stock -
    sounds like substandard materials, as has been noted by several posters -
    I hope we can keep our real yards - these big boxes sound just terrible -
    "there's enough for everyone"
  8. gb93433 | Nov 01, 2008 07:47pm | #27
    Your ten percent failure rate is helping to pay our national debt off quicker.
  9. User avater
    Matt | Nov 02, 2008 11:26pm | #29
    sorry - maybe I missed it... are you talking about hand driven nails or shooters?
    1. geoffhazel | Nov 03, 2008 01:30am | #30
      Hand driven.
