Does anybody use a jobsite tool cart?
Wango1 | Posted in General Discussion on April 8, 2013 10:13am
I have been remodeling kitchens and have a need for a mobile cart to keep tools in and on. Until the countertops get there, there isn’t anyplace to set down tools. (And when the countertops do get there, I’m done.) I see a small enclosed base cabinet on wheels that has a tool rack and holsters for drills. Something I can lock up at the end of the day. Something that shows off our skills. Small enough to get between cab’s, maybe a small vise to hold work/panels?
Anybody out there using anything like this at the moment? Pics? Your 2 cents worth?
  1. DanH | Apr 08, 2013 10:19pm | #1
    I've certainly seen this sort of thing at the plant where I used to work.  Probably 20 different variations.  Often they'd start with a restaurant busboys's cart, (or a similarly-designed industrial cart) then add shelves and doors and whatnot. But others were custom-built from casters up.
  2. calvin | Apr 08, 2013 10:46pm | #2
    wango
    I have a small 4 wheel cart w/collapsible handle-that works.  Anything bigger-I don't think would work in the kitchens I've put together.  This holds the heavy stuff and things I need to be able to move, yet get to.
    A folding 2 wheel to move cabs about is indispensible.
    The festool vac-all the other systainer tools can stack on top and  move around on wheels if necessary.
    Temp plywood on cab bases hold alot of what I use and I set the base cabs first.
    1. Wango1 | Apr 08, 2013 11:12pm | #3
      Any pics? Drawings/ What are your Pros and Cons of your particular cart?
  3. jimjimjim | Apr 09, 2013 03:06am | #4
    Wang,
    My 2 cents but sorry, no pics.
    Tools in 5 gallon buckets organized by trade.
    Tools and materials in milk crates on a 2-wheel dolly (goes up steps and stairs).
    A (removed) door or temp ply on sawhorses or cabs.  Clamps rather than a vice for holding work (but there is always a vice on the truck).
    Saw table that a Makita table saw drops into.  Rack (extensions) for the miter saw.
    A rubbermaid cart with big casters/wheels.
    A dolly for reels of wire.
    A lockable job box (the only item on my list with any semblance of security).
    Regards,
    Jim
Old House Air-Sealing Basics
