Does it matter which way door swings?
kgregor4 | Posted in General Discussion on October 25, 2006 06:02am
36″ Door from Mudroom to attached Garage needs replacement.
Currently swings into Mudroom (away from Garage).
Door Company comes out yesterday to look it over and says it’s “illegal”, that Passage Doors from a Garage to dwelling must swing into the Garage.
Rational is that an “explosion” in the garage would not be able to blow a door open past the jamb it seats against.
Is this really true?
I’ve lived in 7 houses that had inswinging doors from attached garages. Didn’t realize how unsafe I was for these last 47 years.
  1. Abe | Oct 25, 2006 06:29pm | #1
    Sounds like they have a surplus of doors that swing out.
    It may also be a local code.  The main reason I have heard for having doors that swing out is for commercial buildings where it is for safety reasons.  Such as evacuations where a crowd surges against a door, so you would want it to open.
    One of the benefits for a outward swinging door is that it would be a lot harder to kick in.  But a friends house was robed when the bad guys popped the trim and cut the nails and screws with a sawzall or something like that.  They were pro's.
    Finally I would guess that the garage doors & windows would blow out first before a properly installed door.
    1. kgregor4 | Oct 25, 2006 06:48pm | #2
      If a Door were to swing out wouldn't it be an easy matter to pull the Hinge Pins? Doesn't seem like any added security there.
      1. WINSTALL | Oct 25, 2006 10:55pm | #13
        NOT WITH N R P HINGES...
        BillHartmann | Oct 26, 2006 02:46am | #14
        Why would anyone be concerned about the security of a garage to house door.If they get into the garage then a door, no matter which way it opens or where the hinge pins are, is not going to stop them.A few years ago there where some robberies in upscale areas. They used a large box truck with a rollup door. They would backup to the garage and open the truck door. Then used a chain saw to cut through the garage door. Then carried the loot out into the truck.To any passerby's it just looked like another trade truck.No one the wiser until they where done and the truck pulled out.
        BruceT999 | Oct 26, 2006 04:52am | #18
        You can use hinges with fixed pins and/or fit the door edge with security pins that engage the jamb when the door closes.BruceT
      4. rasconc | Oct 26, 2006 07:53pm | #24
        The better exterior hinges have a little tab on one leaf and opposing hole that prevent casual removal with the pin popped out.  Would not stop determined crook with decent prybar though.
        1. doorboy | Oct 26, 2006 08:57pm | #25
          My guess is that if they are in your garage, then they have access to a decent prybar."Kinky for Gov. of Texas"
      5. JohnSprung | Oct 26, 2006 09:55pm | #26
        I've done a little fix on existing hinges for outswings.
        With the door open, drill a pilot hole thru one side of the middle knuckle and just far enough to put a small divot in the side of the pin, working from where the hole will be hidden when the door is closed.  Drive the pin out, drill out and tap the hole to take a 10-32 setscrew.  File a flat about 3/32" deep on the side of the pin where the divot is.  Drive the pin back in place, with the flat facing the tapped hole.  Lock it in place with an allen head setscrew.
        Of course the next thing that happens is a few years later, I've forgotten all about it, and go nuts wondering why I can't get the &^%$& hinge pins out....   ;-)
        -- J.S.
        1. stevent1 | Oct 26, 2006 11:13pm | #27
          John,
          Another way to secure out swing doors is back one of the middle screws on the middle hinge out about 3/8" to 1/2" Cut the head off. Remove the opposite screw on the other leaf. When the door is closed you cannot pull it off the hinges.Chuck Slive, work, build, ...better with wood
    2. hvtrimguy | Oct 26, 2006 06:25am | #20
      just a thought, how about a dead bolt for added shear resistance?"it aint the work I mind,
      It's the feeling of falling further behind."Bozini Latini
  2. DanH | Oct 25, 2006 06:52pm | #3
    Check local code (call the local BI). Some places require outswinging, some require inswinging, some don't care.
    The door should be fire-rated, though, even if local code doesn't require it. Ask the BI about that too, and how many minutes the rating must be for if required.
    Seven blunders of the world that lead to violence: wealth without work, pleasure without conscience, knowledge without character, commerce without morality, science without humanity, worship without sacrifice, politics without principle. --Mahatma Gandhi
  3. woodway | Oct 25, 2006 07:53pm | #4
    In my area, the door to garage can swing either way. Regardless of where your located, it must be a 1 hour rated door and self closing. That requirement means that the door must be at least 20 minute fire rated, usually means a fixed label on it's edge indicating it's fire rated door, and have at least two spring loaded hinges that will cause the door to close on its own.
    As was pointed out earlier, an outswing door has it's hinge pins on the outside(garage side) of the door so security could be an issue. Check with local building official or just call building permit dept. on the phone and they will tell you that much regarding swing of the door in question.
      xxPaulCPxx | Oct 25, 2006 09:55pm | #10
      Carefull about the spring hinges - in my area they are not allowed, you have to have a mechanical closer mounted.Rebuilding my home in Cypress, CA
      Also a CRX fanatic!
      1. doorboy | Oct 25, 2006 10:00pm | #11
        Be careful with that mechanical closer. If you use one, the hinges MUST be ball-bearing type and UL or Warnock Hersey approved--as would all hardware, door, frame, and any other component used in the doorway."Kinky for Gov. of Texas"
        1. DanH | Oct 25, 2006 10:07pm | #12
          Maybe it's best to just not have a door.
          1. hvtrimguy | Oct 26, 2006 06:31am | #21
            what about them beads they used to hang in the opening? are they fire rated? no swing to worry about !"it aint the work I mind,
          2. doorboy | Oct 26, 2006 07:33pm | #22
            I like the beads idea. I don't know, but if they were made of the correct composite material, it should pass a fire test.
            Would you have to listen to SITAR music all the time?"Kinky for Gov. of Texas"
    abutcher | Oct 25, 2006 08:47pm | #5
    I would think about ease of use. I would not want to swing the door open toward me while standing on step in the garage, because I would have to step back and down to clear the door. It is much easier to push the door into the room while in the garage. The same when leaving the mudroom for the garage. That's my 2 cents.
    1. Bing187 | Oct 25, 2006 09:10pm | #6
      Never heard of the can't swing in rationale; Code says door can't swing onto a stair.
    2. blue_eyed_devil | Oct 26, 2006 02:54am | #15
      That is done all the time if a storm/screen door is installed. Around here, screen doors are somewhat common.
      If the door is higher than two risers, it requires a porch. In theory, you'd either be on a porch or standing on the garage floor.
      blueOur Skytrak is for sale. It has 500 hrs on it. We want  50k (you pay the freight) and we'll finance it. Drop me an email; it's a good buy.
  5. Laumonster | Oct 25, 2006 09:50pm | #7
    Any door connecting the dwelling to the garage has to be fire rated and must have a self closing hinge ( spring loaded ).
    The swing would only matter to the homeowner .usually, but, if it's an outswing door the drop down ( threshold to floor ) cant be more than one and a half inches.
    The swing of a door should also not block any light switches.
    1. DanH | Oct 25, 2006 09:53pm | #9
      I don't recall that any of the new houses we've visited here have self-closing hinges, but then I can't recall that they didn't. I'll try to remember to check that next time we go snooping.Our '76 model year home has a fire-rated steel door, though. Opens inward.
  6. doorboy | Oct 25, 2006 09:52pm | #8
    Local codes will dictate the legality of the opening--not a door company. If this project is subject to permits and inspection, only the AHJ (authority having jurisdiction) has an opinion that matters.
    Life Safety issues and Security issues are two different breeds of cat oftentimes.
    As far as fire rated-doors are concerned, it doesn't matter at all if the wall itself is not a fire rated wall. If your existing door does not have a fire label attached to it, then it is NOT a fire-rated unit.
  7. User avater
    IMERC | Oct 26, 2006 03:05am | #16
    the door swing may be an issue for your locale.. but not likely...
    most door swings are done for convience..
    also sounds like terror tactic selling..
    WOW!!! What a Ride!
  8. Dave45 | Oct 26, 2006 03:07am | #17
    Check your local code, but my garage door swings into the house.  I have two steps down from the house to the garage and I definitely wouldn't want (or put up with) a door swinging over the steps.
  9. hvtrimguy | Oct 26, 2006 06:23am | #19
    guess mine is illegal too. actually never even put the closure pack on. been 6 years now. talk about dangerous living! never heard of that rule but makes sense in a logical way. since all of our building codes are so logical, must be true. (?). don't know man.
    J
    Bozini Latini
  10. User avater
    Ricks503 | Oct 26, 2006 07:53pm | #23
    s other say - likely a local code issue, if true.  My house ( finished 10 months ago) has a door to the garage that opens into the house.
    " There'll be no living with her now" - Captain Jack Sparrow
