Does water wick through PT?
gbcp | Posted in General Discussion on June 13, 2005 06:40am
I know PT sill plates are used alot, but I guess water could wick into the plate and wet the ends of the attaching studs?
I’m replacing the sills and lower 1-2 feets of an outbuilding built on a slab. North side doesn’t seem to dry that well, and the wall is about 2 inches from the slab edge.. Wondering if I should use PT to sister to lower part of studs, or just use normal lumber. Will also replace lower 1-2 feets of sheating with PT ply, or maybe wrap OSB with tyvek to completely cover the bottom edge (which ever is cheaper).
  1. FastEddie1 | Jun 13, 2005 06:47pm | #1
    Yep.  Water wicks through wood, PT lumber is wood, therefore ...
    The difference is that the PT is rot and insect resistant.
    1. displacedtex | Jun 14, 2005 12:34am | #2
      isn't that the point of sil-seal, keep water from getting to the plate?
  2. WayneL5 | Jun 14, 2005 02:03am | #3
    How about building a short wall, a couple of courses high, and build with wood on top of that?
    1. gbcp | Jun 14, 2005 02:36am | #4
      Yeah, thinking about that too.. a little more work... might actually be cheaper.. Would probably install vertical rebar every few blocks and fill with concrete..
