Door Closes By Itself
| Posted in Construction Techniques on September 17, 2004 06:48am
Hi,
I just had a remodel done and I have two interior doors that close (albeit slowly) by themselves. The doors are very heavy veneered fiberboard. I had the contractor look at them, but he hasn’t gotten it squared away yet. I think I’ll fix it myself, but was wondering what the preferred method is.
Thanks,
Andrew Bell
  1. marv | Sep 17, 2004 07:03pm | #1
    The doors are not plumb.  You can tear them out and re set them or I would take out one of the hing pins and set on cement and tap it in the middle with a hammer.  A slight curve to the pin will make it bind and the door will not close by itself.
    You get out of life what you put into it......minus taxes.
    Marv
  2. DanH | Sep 17, 2004 07:40pm | #2
    Either hire an exorcist or bend a hinge pin.
  3. FastEddie1 | Sep 17, 2004 08:49pm | #3
    Put a level on the hinge jamb and see how far out it is.  It might be prudent to have the contractor re-plumb that jamb.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
  4. JohnSprung | Sep 18, 2004 01:18am | #4
    The "bugger a hinge pin" method has to be used with some care and moderation.  You want to increase the friction in the hinge just enough to stop a slight out of plumb condition from making the door swing.  If you make the hinge too stiff, it puts a huge cryin' strain on the screws, and will eventually cause them to strip out of the jamb and/or door.  If you see the treated hinge bend and flex, even a little, as you move the door, then that's too much.
    -- J.S.
  5. Jemcon | Sep 18, 2004 02:58am | #5
    I Like bungee cords! LOL
    1. DonCanDo | Sep 18, 2004 03:13am | #6
      Funny you should mention bungee cords.  I've got a couple of very light hollow core doors that are perfectly plumb, but the breeze I create as I walk past them is just enough to slowly close them after a while.
      So, rather than bungee cords or "bugger the hinge", I used a very small spring at the top of the door.  It's not enough to actually move the door, but it's enough to keep the door from self-closing as I pass.
      -Don
  6. Piffin | Sep 18, 2004 03:14am | #7
    The only reason for fixing it yourself is if this contractor was so bad that you just don't want him back in the house again. That is waht I suppose since he has not quite " gotten it squared away yet."
    The jamb is out of plumb. Anybody who has hung more than a couple of doors knows this. So he is either very ignorant of his professed trade or he is hiding out and not the kind of contractor you want doing work on the house. Either way, he is a cause for concern.
      Dinosaur | Sep 18, 2004 04:20am | #8
      Piff--
      It's a remod, so it's an even bet the wall is out of plumb, too. Maybe it's out enough that the doors can't be hung any plumber without it being visually obvious. Plumbing the walls or custom hanging those doors so it doesn't show too much is billable extra work; maybe the HO didn't understand that and there's an argument on that point?
      On the other hand, the contractor could just be a slob.
      Need more info to know for sure....
      Dinosaur
      1. Piffin | Sep 18, 2004 05:11am | #9
        You know I do remo work, so I'm not bling to possibilities - but I have never seen a door that could not be hung plumb, even in awall tht is three inches off in ten feet.
        Yeah, it takes a few more minutes but the main thing is does the guy care? That means more than the time involved.
          Dinosaur | Sep 18, 2004 05:38am | #10
          Yes, the door can always be hung plumb--but getting it that way in a wall that's out by 2" in 7' is gonna require one or several of the following things:
          Trim a wedge off one side of the jambs and shim the other, so they'll come flush with the wall; or
          Fabricate a new set of jambs to match the slope of the wall and mortise in the hinges on a plumbline; or
          build up the 'rock with compound until it's half-way there, at least; then
          Pull and re-install the stop bars; or
          Just move the goldurned wall....
          Sometimes it'll be so in-your-=face obvious that things are out of whack when you're done hanging that door dead plumb, that it'd actually be better to cheat a little and bind the hinges just a tad.
          Anyway you look at it, it's extra time, extra work, and an extra charge. I don't think we disagree on that.
          So, yeah, does the contractor care is one of the prime questions here. But we don't know how much of the above the HO here understands, cause we don't know what the contractor ran into or tried to explain to him, or whatever....
          But you're probably right and the guy is just a typical slob. (I'm just playing devil's advocate for a change, LOL....)
          Dinosaur
          1. Piffin | Sep 18, 2004 06:49am | #11
            You forgot one - wide jamb and wedge shim behind the casing
            Dinosaur | Sep 18, 2004 07:06am | #12
            I think I follow you. What I do sometimes is biscuit extensions to the jambs till they're wider than the wall by the amount it's out of plumb, then nail filler strips to the face of the gyprock to hold up the outer edge of the casing. Those fillers have to be tapered from zero to whatever.
            Somethin' like that?
            Dinosaur
          3. Piffin | Sep 18, 2004 07:30am | #13
            Yeah.
            Door on right in this dining room is plumb in a wall that leans out about 1-1/4"
            the 'excavation' shot shows how the wall started out and why it still has a little bit of lean left.
          4. FastEddie1 | Sep 19, 2004 01:07am | #25
            In the "dine north wall" pic ... is that a set of vice grips holding the door closed on the right?
          5. Piffin | Sep 19, 2004 04:35am | #27
            We used temp hqandles to operate the doors during painting. just a square shaft thru the lockset. That way, you dont have a seven hundred dollar trinset and handle muddied up with paint and crap or let the painters get a chance to lose the parts taking them off.
          6. Piffin | Sep 18, 2004 07:34am | #14
            I'm gonna take it back. it qwould be hard to hang a door plumb in this one
          7. User avater
            Dinosaur | Sep 18, 2004 07:40am | #15
            Ain't that the place you lit off tryin' to torch-down them shingles...?
            Dinosaur
          8. Piffin | Sep 18, 2004 07:54am | #16
            Naw, this one is not dying with dignity. It is suffering a slow painful death. Way too slow for my liking. It is on the lot acrosss from my driveway
          9. JerBear | Sep 18, 2004 02:44pm | #17
            Robert Frost called it, "the slow smokless burning of decay".
          10. User avater
            Dinosaur | Sep 18, 2004 08:40pm | #18
            How much the HO wants fer it? Maybe BT could buy it to establish a sort of permanent Fest site....
            Dinosaur
          11. Piffin | Sep 18, 2004 08:58pm | #19
            I think the asking is 67K
            Sits on a 20 acre lake and the site pretty much unbuildable except for this building being grandfathered - until the day it falls down
          12. User avater
            Dinosaur | Sep 18, 2004 09:06pm | #21
            Which explains why the owner hasn't torn it down yet....
            How big is the lot? And is the lake navigable and potable? And fishable, of course?Dinosaur
          13. Piffin | Sep 18, 2004 09:40pm | #23
            navigable, but partially weeded in - shallow. vary fishable. potable only for fish and turtles, oh Yeah, and eagles, owls, osprey, and blue heron...the deer like it and the apple trees too.
          14. User avater
            Dinosaur | Sep 19, 2004 05:15am | #28
            Apple trees...? Must be some nice plump deer in that area....Dinosaur
          15. Piffin | Sep 19, 2004 05:42am | #30
            I just got back from diner at BILs place down the road. Counted ten deer between here and there. We were talking about how they come right up on the porches.
          16. goodwood | Sep 18, 2004 09:02pm | #20
            Hey! Where'd you get that shot of my home?
          17. User avater
            IMERC | Sep 18, 2004 11:58pm | #24
            Give the job to Sphere... His kind of cake and pie...
            WOW!!!   What a Ride!
          18. User avater
            Dinosaur | Sep 19, 2004 05:15am | #29
            Actually, at first I thot it was a pic of his place, LOL....Dinosaur
          19. Piffin | Sep 19, 2004 05:45am | #31
            Trying to bait me into proving that I live in a real house?
            It won't work, I tell ya!
            Just won't work!
            Well, maybe I'll think about it...
            Just for you...
          20. User avater
            Dinosaur | Sep 19, 2004 05:55am | #32
            I meant I thought it was Sphere's place...!
            But that's a nice place you've got there of your own. SO...I guess I really should show ya mine....
            But only becuz we're friends....
            View ImageDinosaur
          21. Piffin | Sep 19, 2004 06:12am | #33
            That reminds me - since we got off the topic of hanging doors plumb, you can be sure the door is hanging plumb on any house, anywhare, by using the old blanket door system. Hang a heavy blanket over the openning by two nails and gravity will hang it plumb for you.
          22. User avater
            Dinosaur | Sep 19, 2004 06:39am | #34
            Yep...and then use Velcro for a strike plate.Dinosaur
          23. JohnT8 | Sep 19, 2004 08:56am | #35
            aaah, you rich folks with your 3 and a half story houses!
          24. raybrowne | Sep 21, 2004 04:55am | #36
            Out of curiosity how far from Boston is that place you are speaking of? I know a number of folks in the market for any kind of real estate for vacation homes, investment purposes, etc.. and that price is about what a parking spot goes for a few bkocks down Commonwealth Ave.
            -Ray
          25. Piffin | Sep 21, 2004 05:07am | #37
            Five or six hours driving, twenty minutes of ferry ride, and a couple of hours waiting in line for the ferry
          26. Mitremike | Sep 19, 2004 01:52am | #26
            Hey Piffin --do you suppose I could make him an offer on the fridge? I need one to make a keg-meister. LOL Mike
          27. DanH | Sep 18, 2004 09:20pm | #22
            Just put the wedge under the door.
Outdoor Lighting
