Door Framing and Hanging
Gagarin | Posted in General Discussion on January 29, 2016 11:36am
 I have a basic question about wall door frame and door hanging.
1. How should custom made door wall frame be attached to already existing wall? [screews/nails]
2. If i have a door without a Jamb can i hang it directly on a Jack Stud or i need to make a Jamb and then to Jack Stud?
here a pic im refering my project to:
  1. calvin | Jan 29, 2016 12:50pm | #1
    Greetings
    1.  Either, but not drywall screws.
    2.  Usually doors are hung to a jamb, jamb set to the wall.  Adjust rough openings accordingly with some shim space or damn fine framing.
  2. john7g | Feb 02, 2016 08:39pm | #2
    Use a jamb so you can fine tune it to plumb and have a good piece of wood for finish. Studs get covered by the drywall and hanging the door directly to the jack stud will make for a lot of irritating detailing when it comes time to trim
  3. mark122 | Feb 03, 2016 10:06pm | #3
    hangin a door directly to a stud? why?
    did you make the RO to small and need the additional 1.5" ?
    unless its your house, no one would accept.
