I have several wooden exterior patio doors with full-length thermal windows which need replacement due to degredation of the seal, causing fogging within the window. I have the replacement glass units, but I am uncertain how to remove the old glass. I cannot determine by visual inspection whether the window trim is removed from inside or outside the door. I don’t see any brads in the trim on either side of the door. Does anyone have specific knowledge as to how the removal and replacement should be done? Thanks.
Listeners write in about HVAC company consolidation and stains from supply lines and ask questions about Larsen trusses and insulating stucco houses.
