Door hinge question
JohnCujie | Posted in General Discussion on December 24, 2008 10:31am
On a hinge with unequal legs, say 4 x 5, which dimension is designated first? Height or width? Trying to find some 4 high, 5 wide and the catalogs don’t indicate.
Thanks, John
    Sphere | Dec 24, 2008 10:37pm | #1
    Goiing by this I'd say the first # is the vert. dim.
    View Image and this at 4x6
    Edited 12/24/2008 2:39 pm ET by Sphere
  2. Riversong | Dec 24, 2008 10:41pm | #2
    The primary dimension is the height. Most standard butt hinges specify only the height, as the width is proportional.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
  3. mike4244 | Dec 24, 2008 11:35pm | #3
    The first # is the hinge width when fully open. Your description is 4" wide and 5" high.Each leaf is 5" high, the width actually will measure about 1 3/4" wide without the barrel. That is why the width is measured with the leaves open flat.
    mike
    1. JohnCujie | Dec 24, 2008 11:59pm | #4
      Now I have two opposite answers. Anyone else?
      Found it on the McKinney site. Height first, then width wide open.
      John
      Edited 12/24/2008 4:07 pm ET by JohnCujie
      1. Howard_Burt | Dec 25, 2008 12:37am | #6
        That's the way they do it at Hager too. Height first, then width. Here's some information on how to specify hinges properly.
        http://www.hagerco.com//images/catalog/information/1-GI_web.pdf
      2. Piffin | Dec 25, 2008 01:03am | #7
        H x W
  4. danman12 | Dec 25, 2008 12:11am | #5
    height first, then width.  end of story.  any other answer is probably from a college kid hired at ahinge factory to try and cut costs 5 cents a unit but doesnt really know anything about the business.
    much like most other companies it seems these days.
    Dan Lynn, Dan Lynn Construction, Joliet, IL
    QUOTES TO LIVE BY:  'The bitterness of poor quality lasts far longer than the sweet taste of a low price....'        'Anything worth doing is worth doing well'       "If it was easy......ANYBODY could do it"
