I have used PC and enjoyed it. Make sure you keep spare parts. Employees don’t mind specialty tools like the actual owner does.
Kelly
The FHB Podcast team weighs in on Building Science career questions.
I have used PC and enjoyed it. Make sure you keep spare parts. Employees don't mind specialty tools like the actual owner does.
Kelly
Bruce, I owned a Bosch template guide, easy to set up - really idiot proof - one problem, there are hand knobs that must be adjusted when you transfer from jamb to the door itself, and for the life of me and the Skil-Bosch service, just couldn't keep them from falling off. If you are thinking of buying a template,try looking around for a old Stanley setup, just about the best- in all around and will take wear and tear. One more thing, it could save a lot of money-- just make it out of plywood-works just as well - doesn't look as professional, but looking at the hinges placement on a new door, you could never tell what template was used. Good Luck!
Bruce:
In the 70's I used a stanley template, and in the 80's I used a PC template. Now I use a Bosch -they are all about the same template. For the money -you cannot go wrong.
*I use a Milwaukee kit and am very satisfied. The parts fit in a metal box and there are basically only five different pieces.
Any opinions on door hinge templates. PC vs.Bosch vs. the more inexpensive plastic. Cost is not the object, doing the job with the least fuss is.
