Door in concrete block
Jemcon | Posted in General Discussion on February 22, 2005 03:49am
Has anybody ever installed an entry door in a block wall without wood framing in the opening? I looked at a door today in a garage that was installed right in the 2×6 frame.
If I rip out the jamb there will only be concrete block in the opening. If I install a new 2×6 frame then install a prehung unit the door will be smaller than it is now.
Is it possible to just shim and screw the new jamb in the block with tapcons. Or should I buy a slab and mae the jamb out of 2×6’s like is there now.
Thanks to all. JEM
  1. brownbagg | Feb 22, 2005 04:41am | #1
    I use 2x8.
    1. Jemcon | Feb 22, 2005 04:48am | #2
      Do you use 2x8 for the framing or the jamb? Is it possible to install the prehung door without wood framing in the opening to save space. i can get a larger door in without the 2x around the jamb.
      1. calvin | Feb 22, 2005 05:15am | #3
        It is possible to install a prehung entry in the block wall.   Be concerned with moisture control wicking from the block.  Line the opening with peel/stick flashing (Ice and Water shield, sold in narrower rolls).  The R.O. will probably be too big for the prehung unit.  Fasten maybe 1/2" (or whatever makes it right) treated ply with tapcons, then the door unit which you'll have to fasten with tapcons as well.  Or, get a commercial door with steel frame, have them prep for surface mount.........that is if the opening is right.Remodeling Contractor just outside the Glass City.
        Quittin' Time
        1. ckeli | Feb 22, 2005 07:34am | #5
          I used this exact method once...
          wrapped the entire opening in ice/water shield, installed 1/2" ttd ply on the hinge side (was all I could add due to spacing) ...filled the sill with roofing cement to keep plyable and up the sides a foot-a solid bead- and set door, and screwed it in with tapcons.  finished it up with minimal expanding spray foam insul.. solid and true"knowledge without experience is just information."  Mark Twain
  2. mdresimprov | Feb 22, 2005 05:27am | #4
    In a garage or service type door you may be able to get away with tapcons. The blue paint is pretty noticeable. If it is an entry door or a more discerning customer, than you need to match the screw heads. Two ways that I've used: one is to drill the concrete and insert a wood dowel with PL. After the dowel is set it will allow you to screw your hinge screw it. Another way is to predrill and install a masonry sleeve anchor, again with PL. After its set run the hinge screw in and adjust. I've used these methods on res. and comm.projects without pullout or sag.
    Mark
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
