Door Installation Level
jocobe | Posted in Tools for Home Building on March 21, 2004 02:49am
I have your basic metal 4′ level and I’d like to upgrade to a better model.  In this month’s issue of Fine Homebuilding it looks like they’re using a 4′ wooden level…. I always heard those referred as ‘mason’s levels’.  I was looking in Amazon and they have ‘Stabil’ levels.  I was thinking either a 6′ or 6’8″ model.  What would you guys recommend as a great level for door installations?
Thanks!
jocobe
  1. Paradiscic | Mar 21, 2004 03:05pm | #1
    Get the 6'6" level from stabila and you will hang doors with a smile for months.  Spend the money and get it, you won't regret it.  I hang lots of doors and that level took atleast 5 minutes off my time per door and I hand better doors.  The straight edge on the jamb allows you to make the jamb straight and plumb very quickly.
  2. VinceCarbone | Mar 21, 2004 03:06pm | #2
    Jocobe,
    The Stibila levels are some of the best in the industry.
    But I use a Levelution which has three parts, two 2' sections and one 4' section.
    It makes levels in 2',4', 6'and 8' from the three parts it's accurate and adjustable.
    Vince Carbone
    Riverside Builders Franklin NY ICQ #47917652
  3. gdavis62 | Mar 21, 2004 03:30pm | #3
    Spring for the Stabila "door hanger's kit" which is two levels, one at about 78" and the other at 32".  Come packaged together, often on sale at both for the price of the big one.
      jocobe | Mar 21, 2004 04:39pm | #4
      I was looking at that one.......where does this usually go on sale?
      1. SunnySlopes | Mar 21, 2004 04:46pm | #5
        Just buy it!    If you concerned about the price of a tool then you are not charging enough for your jobs.
        "One measurement is worth a thousand expert opinions"
        Edited 3/21/2004 9:46 am ET by Woodrow
          jocobe | Mar 21, 2004 04:48pm | #7
          "Just buy it!    If you concerned about the price of a tool then you are not charging enough for your jobs."
          You're right!
          1. mikerooney | Mar 21, 2004 07:14pm | #8
            Get the magnetic set - $159.99 @ amazon. You can hang the 78" on the hinge barrels of a pre-hung door.
            jocobe | Mar 21, 2004 07:54pm | #9
            Yea...I saw that one after I posted the other pic.  I was thinking it was just for steel doors. but I was wrong......that's the one I'll get.
            JeffBuck | Mar 22, 2004 12:34am | #10
            ditto on the magnetic jamber set ....
            it's saved countless hour and frustration ...
            plus ... ya hit yourself on the back of the head way less  ......(from a falling level)
            Stick it .. shim it .. straighten it ... all in one fell swoop.
            Can't say enough good about it.
                 Artistry in Carpentry
            jocobe | Mar 22, 2004 12:53am | #11
            How do you stow it in your truck.....I see that a case is available, however one guy on Amazon did not give the case a good review.
            Edited 3/21/2004 5:54 pm ET by JOCOBE
            JeffBuck | Mar 22, 2004 01:42am | #12
            the case isn't the best ...
            as soft sided cases usually aren't ...
            and ...it's expensive ...
            But I'm glad I got mine.
            Holds the 6'6" ... the 32" .... and the 4ft'er I already had.
            I just throw the levels in last on top of what ever pile I have growing in the van ....
            So far it's been a coupla years ... no damage yet.
          6. Paradiscic | Mar 22, 2004 02:28am | #13
            I agree with Jeff, the case has a lot to be desired, but it does protect the $150 level you just bought.
            By the way I do quite a few large cased openings.  The plate level makes quick work of a 15' wide cased opening.  With it extended to 10' you can straighten one side of the head jamb so it is level with the other side, then flip the level and straighten the other side of the head jamb.  Can do the big ones in about the same time as a 4-6' cased opening.
          7. User avater
            JeffBuck | Mar 22, 2004 02:35am | #14
            ya know .. I never thot of the plate level for a use like that!
            That's be ideal for long runs of cabs .....
          8. Paulgern | Mar 22, 2004 09:44am | #15
            i never thought of mail ordering a level.they actually arrive in the mail and read true? what is a plate level?
          9. User avater
            JeffBuck | Mar 23, 2004 04:16am | #16
            I believe I got my first Stabila thru the mail ... tool crib.
            picked up the door hanger set at woodworkers or woodcrafters on sale locally.
          10. Paradiscic | Mar 23, 2004 05:26am | #17
            A plate level wider than a standard level because it expands from 6' to 10" (or 7' to 11").  It was designed for framers (but we all know they don't know how to read them any way :) ).  They are "used" to plumb a wall bottom plate to top plate.  I got mine when WWW went out of business for $100 but it works GREAT for wide cased openings.
          11. gdavis62 | Mar 23, 2004 06:15am | #18
            It'll probably come to you in a UPS delivery truck, and a bigger UPS truck transported it over the road.  Not too different from the way they get to the tool stores.
            Look, they UPS laboratory equipment and medical gear all the time.  Why are you worried about your Stabila level?  You'll be rougher on it than UPS ever will.
          12. Paulgern | Mar 23, 2004 07:41am | #19
            it wasn't the delivery of the level i am concerned about. someone in a warehouse has to pick it . very few of the levels at our lumber yard actually read true(no they are not stabillas) i find it hard to pay 150 bucks for a level i can't check. that said, i have had my levelution for 4 years. adjustable-that is its selling point. i hate it. it has to be adjustable cause it wont stay inadjustment. its been sent back to the factory and had vials replaced but to avail.
        jocobe | Mar 21, 2004 04:46pm | #6
        This one?
        Stabila 24632 Jamber Set with 78" and 32" LevelsStabila
        List Price:
        $215.20
        Price:
        $129.99
        You Save:
        $85.21 (40%) Availability: Usually ships within 24 hours
        This item ships for FREE with Super Saver Shipping. See details.
        See more pictures
        Features:
        Box frame will not warp or twist
        End caps are removable for flush measuring
        32-inch level is perfect for leveling and setting headers and sills
        78-inch level now has hand holes
        Accuracy guaranteed for life
