Door Jamb
boxcar955 | Posted in Construction Techniques on August 18, 2006 01:37am
I have a client who bought a door and jamb from  Menards. They painted  door looks good now the problem is it is a jamb for a 4inch  wall and it is a 6 inch wall it was installed by them selves but to trim it out you need widerjamb any suggestions Menards wants just as much for new jamb as they do for door and jamb combined.
  1. jeffwoodwork | Aug 18, 2006 01:43am | #1
    If it is a painted jamb just add some extensions, like a 3/4"x1 1/2" popular or hemlock glue it nail it fill the seam and paint.
    1. T3 | Jan 23, 2010 02:06pm | #12
      i don't think this will
      i don't think this will correct the sagging of the door. which creates the gap.
      1. DanH | Jan 24, 2010 03:23pm | #15
        We have another case of two threads with the same name getting confusicated by the crummy software.
    IMERC | Aug 18, 2006 01:58am | #2
    pick up a jamb extension kit and use that...
    WOW!!! What a Ride!
  3. CAGIV | Aug 18, 2006 02:07am | #3
    Is this an interior or exterior door?
    I'd be tempted to build a new jamb for an interior door, shouldn't take to long and looks better then extenstion jambs IMO.
    Worst case is to make some jamb extensions
    Team Logo
      boxcar955 | Aug 18, 2006 03:41am | #4
      Itis a painted jammb exterior door Will a good primer help seal it up you know for areasonable time to help prevent it from rotting out.
      1. marv | Aug 18, 2006 04:18pm | #5
        Jamb extensions are the answer.
        But here's a tip.  If the door jambs came with brickmold already on it, take it off.  Install the door flush with the INSIDE wall.  This way the hinges will be proud of the interior wall as they should be.  Then apply your jamb extensions to the bring the door flush with the outside wall.  Re-apply brick mold.You get out of life what you put into it......minus taxes.
        Marv
          boxcar955 | Aug 18, 2006 11:06pm | #10
          Thanks  everyone I guess I will check into sill and jamb extensions. Customer like I said had already installed and painted door I was just an after thought like gee now what can we do ?  Thats when I  got the call to help out  poor gal said  its been this way for a couple years also get to trim out two bedrooms and living room plus install some bifold closet doors . Hubby is a  car salesman and has know clue what to do. You got to love it.
    Heck | Aug 18, 2006 04:41pm | #6
    Jamb extensions and a sill extender will fix you up.
    "Citius, Altius, Fortius"
    hammer1 | Aug 18, 2006 05:17pm | #7
    All you need are some extensions on the inside to come flush with the sheetrock. Hold the extensions back from the jamb edge with a reveal, just as you would with a casing. They have to fit behind the hinges which will make the reveal about 5/16" - 3/8". This also keeps the swing of the door from hitting the extensions.
    Allowing customers to pick up the material is always a bad idea. I ran into an install like yours where the customer bought the door from the discount rack. The door must have been hit by a truck, twisted, and the jamb was the wrong size. What should have been an hour job turned into half a day. The customer saved $50 on the door but paid an extra $200 for the install.
      IMERC | Aug 18, 2006 06:00pm | #8
      the sill extender generally goes to the out side..
        hammer1 | Aug 18, 2006 08:18pm | #9
        If the six inch wall already has the four inch door installed, all you need is an interior extension jamb and that doesn't require a sill extension. Way back when 2x6 framing was somewhat new, door manufacturers offered extension kits for their four inch units. These would include an extension for the sill and were also an area that could be subject to leaks, depending on how the extensions were attached. Pan flashings were not commonly used, although they are just a back up. These days you just order the door for the thickness of your walls. Trouble is, they only come in two sizes. If you use something other than 7/16" sheathing, apply foam board under the drywall, have masonry or anything, other than the norm, you have to be a little creative. Making minor adjustments on the interior may reduce exterior weather issues. From past experience, i'd avoid exterior sills with a joint. The better doors have solid sills in both sizes. Jambs built for 6" walls actually have 6" of sill exposed to the exterior, beyond the door. That's a pretty big semi-flat spot and not a place where I would want a joint, especially a caulked joint. With some wider interior extensions, you may have to use thin material, bevel back and maybe alter around the RO so it doesn't interfere with the operation of the door. The lock strike often hits the interior extension and scratches it. It's easy to form a piece of brass sheet for that area, almost looks normal.Beat it to fit / Paint it to match
          Heck | Aug 19, 2006 12:54am | #11
          Interior extensions don't allow the door to open as far."Citius, Altius, Fortius"
        2. T3 | Jan 23, 2010 02:17pm | #13
          it sort of looks like the door is sagging from the head jamb. sorry if i explained it incorret. but the door is flush with the wall, so i wont need a door extension. it just looks like its sagging from the head jamb.
    2. T3 | Jan 23, 2010 02:25pm | #14
      i paid full price for this door at the big store called lowes and it was the best one out of the bunch.it should not be sagging like that. maybey i should of grabbed the worst one.i might of had better luck.
  • A Postwar Comeback
