Door Manufacturer?
tuesdayhouse | Posted in General Discussion on April 9, 2007 11:29am
Hi – I am trying to figure out the manufacturer of a set of French doors in a client’s house. The doors are wood clad with a single light. They have brass hardware with a lever handle that you push down to open and pull up to lock. The metal strip that runs up the inside width of the door opposite the strick plate has the letters “G U” and a logo that looks like a “F”. There no other distinguishing marks on the doors. It is hinged in the middle. I need to get the doors repaired as the seal around the double pane glass is coming off and water seeps down the glass and into  the door. Any help is appreciated.
  1. Kaya | Apr 09, 2007 11:54pm | #1
    I can tell you that the hardware is made by Gretsch-Unitas, a German company, but I'm pretty sure that the actual doors were not made by them.
    It sounds like you might need a carpenter or glazier for the repair work.
    1. tuesdayhouse | Apr 10, 2007 06:57am | #2
      Thanks - that actually helps!
      -JMK
Drafting the 2027 IRC
  • The New Old Colonial
