how is the best way to repair a hole in a hollow core stained door?
Cash.
In the hands of the lumber yard that sells new doors.
"If Brains was lard, you couldn't grease much of a pan"
Jed Clampitt
Yeah--that is what I was afraid of :(
I know that Sphere's response may seen crass, but a lot of us here would welcome the opportunity to replace a hollow core door with a real one, which is why we may carry a lot of heavy tools in their proximity.
I didn't mean to be crass, just avoid spelling out a detailed process that could lead to even more headache and trouble than the door is worth.
I mean, a pin hole is one thing, a fist is another. And I have better things to do than restructure a veneered stained hunk of lauan and I'd guess most other folks do too. When a new slab is 25 bucks for A 2/8 ^6/8 Lauan HC.
Then ya hang a solid core on a split jamb that wasn't shimmed and tacked up with 2 finishnails in the trim..yeah, Been there, done that...make it a 1/2 day now just to replace the door AND re attach the jamb...oooops, the wall paper tore...LOLSpheramid Enterprises Architectural Woodworks
You got it, Sphere. Good night.
Sphere: I second your opinions of carps who hang doors w/ their casing trim. My daughter bought a house in MS that I've been doing a lot of work on. Every interior door that I've worked on has been that way. Not a single door has had even the hinge side shimmed & the top hinge fastened w/ a screw long enough to reach the studs. Whoever did the frame carpentry was generous w/ the opening - leaving as much as an inch on either side & none of the studs have been even remotely plumb! After a few doors, I realized that the reason that there was nearly a half inch gap between the slab & jamb was a total lack of shims on either side. I've had to rip long strips of 5/8 ply to fill some of the gaps, then shim to make plumb. DonDon Reinhard
The Glass Masterworks
"If it scratches, I etch it!"
I've always figured that if it's a busted-in spot with the wood still intact, you could probably drill a small hole or three and CAREFULLY inject spray foam to pop it back out and brace the area. Then with some careful puttying and refinishing you could have a reasonably decent looking patch.
At least it wouldn't cost much to try.
Let me save you some time. You can't. I had exactly the same thought and tried it on a door my sons put an elbow through. I say "sons" plural since neither would admit to it. Anyway, the foam went everywhere except into the door, it didn't push the face out and made a big mess. I finally used Bondo and painted the door.
replace the door and be happy, grumpy
