Door sill replacement
tab1 | Posted in General Discussion on September 21, 2007 10:34am
I presume the only reasonable way to replace this rotten sill is to remove the trim and jambs? If so, and while I’m there, would it be a good idea to try to raise the sill a bit (and shorten the door) to increase the distance from concrete sidewalk to top of sill?
Thanks.
    JDRHI | Sep 21, 2007 10:41pm | #1
    Working like a surgeon, I've been able to remove thresholds without touching the trim and jambs. It's tedious, trial and error stuff....and I'm not sure it would work in your situation, as the threshold appears to actually sit below the exterior concrete.
    Rather than go through all you are contemplating, I would consider yanking the entire unit.
    If possible, raise the header frame so that you could still fit a standard 6'8" door in there while giving yourself at least a 4" step up below the threshold and get a whole new unit.
    J. D. Reynolds
    Home Improvements
  2. Muttly | Sep 21, 2007 11:05pm | #2
    I think you should be more worried about the sub-floor, rim joist and mud sill. By the time you get all that rot out the door will look easy.
  3. acornw | Sep 21, 2007 11:06pm | #3
    Yes, pull the frame and replace the sill and perhaps the side jambs. If the sill is that far gone, the jambs will be spongy, too.
    Rest the thing so the top of the sill is 3/4" to 7/8" above the finish floor (sic). This will give room for a walk off rug to help absorb moisture and prolong what is left of the (alleged) finish floor.
    Wonder where the water goes?
    Dave S
    acornwoodworks.com
    1. rez | Sep 21, 2007 11:30pm | #4
      Hopefully to an open space between the concrete stoop and the basement wall but ya know, it doesn't look that way.
      eek!View Image
      sobriety is the root cause of dementia.
    Sphere | Sep 22, 2007 12:01am | #5
    You gonna eat them green M&M's?
    "If you want something you've never had, do something you've never done"
    1. rez | Sep 22, 2007 12:19am | #6
      dang but that don't look like my gramma's old house.
      be a very, very, very fine housewith two cats in the yard
        Sphere | Sep 22, 2007 12:22am | #7
        She liked M&Ms too?Spheramid Enterprises Architectural Woodworks
  5. DanH | Sep 22, 2007 03:53am | #8
    Yeah, I'm sure someone could, if necessary, replace the sill without removing the jambs. I've done similar things. It takes a bit of creativity, and might involve installing the sill in pieces.
    Raising the sill might be wise, as it appears to actually be below the level of the inside "finished" floor. Raising the sill would also likely simplify somewhat the job of replacement.
