doorbell button at 24v
grandizer | Posted in General Discussion on August 22, 2006 03:55am
Simple electrical question. I’ve got a circa 1960 door chime (wired) running off 24 volts. The chimes work fine but some of the pushbuttons are broken. I can’t find any buttons at the HD that are rated for 24 volts. Most say 16 v max.
Can anyone suggest a source for 24 v rated doorbell buttons?
Does the voltage rating really matter? I would have thought its a total power (V x I) issue.
  1. DanH | Aug 22, 2006 05:11pm | #1
    I do wish the doorbell folks would settle on a standard. Voltages range from 6V to 24, though 16-18 is probably the norm.
    An unlighted 16V button should work fine. A lighted button would be apt to burn out at 24V.
  2. Brooks | Aug 22, 2006 07:24pm | #2
    You might also see if the doorbell will run off 16v. If so, you
    can use lighted buttons, which are nice...
    1. grandizer | Aug 22, 2006 07:33pm | #3
      I'm hoping not to have to change the transformer. Its in the main elec. box and I imagine that its only connected to the doorbell, but the house is wired so squirrely that I'm not sure if anything else is connected to it.
      1. smslaw | Aug 22, 2006 10:29pm | #4
        I just put in a wireless doorbell.  A nice feature is that it has a different ring for each door button.
    IMERC | Aug 23, 2006 01:02am | #5
    replace the bulb with a 24V model...
    WOW!!! What a Ride!
    1. grandizer | Aug 23, 2006 02:38am | #6
      You mean the bulb in the button?
      I don't really care about a lighted button. Plain is fine.
      So is the concensus that the voltage rating on a plain pushbutton is ignorable?
        IMERC | Aug 23, 2006 03:11am | #7
        so do plain...
      2. DanH | Aug 23, 2006 04:03am | #8
        Well, within reason. I wouldn't recommend using the button to switch a 480V line.
        1. edwardh1 | Aug 23, 2006 04:20am | #9
          lightning took my transformer- new one at lowes was $7
