I’m putting a dormer in a trussed roof(i’m used to rafters).I need a 4 feet space for the dormer. Do I just double-up the trusses on each side of the dormer and header it off or is there an easier solution?
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
Greg,
We occasionally encounter this problem with 4' skylights in truss roofs. The specs are up to the truss designer, but typically it's like you said: double up the trusses either side. Usually we get a double girder truss either side (slightly beefier, chords are 2x6 instead of 2x4) and run purlins between up-to the opening. You could header off at the opening and run a rafter between it and the ridge, and from the ridge to the back wall.
*In general - If the trusses are designed to be 2'on center, you can use a double truss on each side of a 6' opening, and a triple truss for up to a 10' opening. No need for special girders. Definitely check with local codes and your truss company, though. And don't cut trusses out for skylights, dormers, attic fans, etc.
I'm putting a dormer in a trussed roof(i'm used to rafters).I need a 4 feet space for the dormer. Do I just double-up the trusses on each side of the dormer and header it off or is there an easier solution?
