Dot laser level: recommendations?
Biff_Loman | Posted in Tools for Home Building on February 9, 2008 04:35am
Uh, gotta run! Can’t type too much. . . I need/want/gotta have a dot laser level. Don’t want to spend too much. Just for interior layout stuff, so great accuracy over long distances is not necessary.
    BillHartmann | Feb 09, 2008 04:39am | #1
    One dot, 2 dots, 5 dots?
  2. plumbbill | Feb 09, 2008 04:41am | #2
    PLS
    “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
  3. Waters | Feb 09, 2008 04:46am | #3
    I have this one : http://cgi.ebay.com/David-White-Mark-4PL-5-Beam-Laser-Level-NIB_W0QQitemZ320215182328QQihZ011QQcategoryZ63941QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Used it today inside.. but use it out too.
    Cheap on ebay and a good unit.  Can be 'field calib.' if it gets out of whack.  I've done it--it's easy.
    Dbl A's...
    etc..
    "Research is what I'm doing when I don't know what I'm doing..."
  4. USAnigel | Feb 09, 2008 04:59am | #4
    The dot is a pain, get a line type instead. If looking cheap but works well look out for the black & decker unit at HD. There is also a Ryobi that will hold itself on the wall.
  5. mike585 | Feb 09, 2008 06:22am | #5
    The only one I've used is PLS. Worked perfectly. PLS 5x for dots, in or outdoors. Can't go wrong.
  6. MattSwanger | Feb 09, 2008 06:43am | #6
    PLS5x is a great tool,  good customer service as well.
    Woods favorite carpenter
  7. slykarma | Feb 09, 2008 07:27am | #7
    Robo Vector 5 dots. Good visibility and self-levelling. Fits in a tool pouch. Indispensible.
    http://www.blackbookoftools.com/ProductDetails.aspx?ProductID=2343
    Lignum est bonum.
    1. JulianTracy | Feb 09, 2008 09:32am | #8
      I agree - forget the dot types - pain.The PLS 2 or newer 180 seem to be the goto pockt lasers to get.But it looks like Dewalt has introduced a couple new units - a horiz line for about $123 and a vert/horiz 2 line unit for $199.I've had a Dewalt Plumb laser for a few years and it's bulletproof and has a great HD case.Commit to spending the $200 or so - you'll be glad you did for as long as you use it.Other wise - spend $70 or so and get a used David white unit on Ebay. They were discontinued as part of a rebranding of them as Stanley /CSTs and can be had cheaply.JT
